Go to Post Lose lips sink... robots? (during a water game at least) - Zach O [more]
Unread 22-01-2010, 14:32
Guopeter Guopeter is offline
AKA: Pie
FRC #0296 (Northern Knights)
Guopeter is just really niceGuopeter is just really niceGuopeter is just really niceGuopeter is just really nice
Kicker Design Challenge
Has any team been able to design a kicker to load, kick, and re-load, using only one motor?
This is what I'm trying to do.
-Pie Man
-Northern Knights 296
-Beaverworx 2609
Unread 22-01-2010, 14:34
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Kicker Design Challenge
The stepped cam thing should work for that. The fun part is that we want to make ours adjustable as to how far it shoots...not so easy
btw the Kicker is indeed a real Challenge!
Unread 22-01-2010, 14:38
sloteera's Avatar
sloteera sloteera is offline
AKA: Rafa
FRC #1860 (Cephatron)
sloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud of
Yes!
Our kicker is only one motor with gear box!
No springs, no tubings, no pneumatic cylinder!
Unread 22-01-2010, 14:51
riptide's Avatar
riptide riptide is offline
The Software Dude... LabView and VB
AKA: Jeff
FRC #1165 (Paradise)
riptide will become famous soon enough
For those who are not aware, there is a robotics league called RoboCup. This league builds robots that are completely autonomous with the challenge to compete against humans by 2050. This league has been around for some time and they really have perfected kicker design. If you are confused in how to design a kicker, I highly suggest you do a search on Google or Youtube for RoboCup Medium Size to see some of these robots in action. Additionally, some of the teams websites have published papers that talk about their designs. Keep in mind that some of these designs may not be legal per the FIRST rules. Here is a link that might help you out.
Robocup Shooting Mechanism
Unread 22-01-2010, 15:13
gyaniv's Avatar
gyaniv gyaniv is offline
AKA: Gutman Yaniv
FRC #2230 (General Angels)
gyaniv has a spectacular aura aboutgyaniv has a spectacular aura about
Our team actually succeed doing the kick with one motor...
Probably will work with the FP motor. but still it is working with one motor and some springs, and can be also adjustable to the distance we want to kick the ball to.
The hard part in the mission this year is not just to kick the ball far, because you don't need to kick it more then 50feet and about 3-4feet in the air at the highest point. The hard part is to make your kicker adjustable so the kicker operator can adjust it to kick in different distances, for example if you are in the other alliance zone and moving to the midfield so other robot in your team can get in to defense you need to kick the ball 10-25feet less, so if you will build your kicker to kick the ball for 60-70feet and kick a ball from the midfield your ball will just bounce back to the midfield if not go out of the arena. Not to mention that if you build your kicker to kick even for 40feet you will most likely won't be able to get a ball into the goal unless you do it from the midfield or something or just push it to the goal. So teams with a really good kicker design that can adjust the distance the ball goes will most likely be "Wanted" because they can basically play in every part of the field without any problem.
Try thinking of that, i won't give you how the whole kicker works, but you can take guesses and a pic will probably be posted after the regional. (Or you will see the robot on our YouTube channel: http://www.youtube.com/user/Team2230 )
FRC Team 2230 - Student - 2009-2011
FRC Team 2230 & 4406 - Mentor - 2012
FRC Team 2230 - Mentor - 2013-present
"A mentor's job is to understand what the students are trying to make, and bend the laws of physics to make that happen"
Unread 22-01-2010, 15:27
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
We have one in the works using surgical tubing to kick the ball. Our design is inspired by team 284's 2008 robot seen here.
http://www.chiefdelphi.com/media/photos/30419
http://www.chiefdelphi.com/media/photos/30400
We tried a similar setup on our 2008 robot and it seemed to work very well.
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 22-01-2010, 15:46
gyaniv's Avatar
AKA: Gutman Yaniv
You are not building a catapult i hope
Unread 22-01-2010, 16:54
AKA: Cliff Mock
why? not allowed?
No we are not building a catapult we are applying the system as a kicker
Unread 22-01-2010, 17:26
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
I'm seeing more teams realizing the importance of a variable force kicker.
Been looking for signs that someone is contemplating an 'aim-able' kicker but nothing yet.
I guess most teams are thinking a nimble bot will do in place of a directional kicker.
I haven't given up yet though, there's still time.
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Unread 23-01-2010, 00:27
Your chain is touching the carpet as you go over the bump.
Violation of Rule <R08>
http://forums.usfirst.org/showthread...ighlight=chain
Unread 15-02-2010, 14:28
K Lenox's Avatar
K Lenox K Lenox is offline
I AM GOD IN GEARS OF WAR!!!!
FRC #2632 (Comets Unleashed)
K Lenox is an unknown quantity at this point
All you guys are using a Kick with one motor. Team#2632 has made a motor that is made up of a peice of wood, a bungie, a metal rod(Axis) and a metal arm(to pull wood). We are able to go 13 inches inprecisly 02.78 hundreths of a second...............BOOYAH!!!!
[font="Times New Roman"]
You never saw this message
You never read this
You will read the next available object within sight
Why are you still reading this???  Begone with you!!!
[SIGPIC]
Unread 15-02-2010, 14:50
That's quite a motor. You should file for a patent :-)
But all seriousness aside, how did you measure to a precision of tenths of a millisecond?
Spring Powered Kicker Design Jeeman Technical Discussion 1 19-01-2010 08:08
FIRST (Tech Challenge) mentioned in Design News Elgin Clock FIRST In the News... 1 23-03-2009 18:11
CAD Drive Design Challenge CraigHickman CAD 12 06-08-2007 03:19
pic: 1930's Design and Problem Solving Challenge Tetraman Extra Discussion 1 29-09-2006 20:25
Design Challenge: Baton Mike Technical Discussion 27 12-12-2005 16:41
