Go to Post In the now immortal words of will.i.am, "This stuff is really good!" - neshera [more]
Unread 22-01-2010, 15:30
kylelanman's Avatar
kylelanman kylelanman is online now
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
2481 Drives Over the Bump with Mecanum Wheels
At the beginning of the season there was discussion as to whether or not a mecanum drive could make it over the bump.....IT CAN!!!
http://www.youtube.com/watch?v=UzgTftW_Cow
Questions, comments and suggestions welcome.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 22-01-2010, 15:38
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: 2481 Drives Over the Bump with Mecanum Wheels
Does not surprise me, as mecanum wheels work reasonably efficiently going forwards/backwards (especially if the rollers have a bit of tension).
Would probably work even better with carpet on the whole floor
Unread 22-01-2010, 15:52
gyaniv's Avatar
gyaniv gyaniv is offline
AKA: Gutman Yaniv
FRC #2230 (General Angels)
gyaniv has a spectacular aura aboutgyaniv has a spectacular aura about
Have you tried crossing the bump vertically?
I don't think it will work with mecanum wheel, but i would love to see if it does...
We are going on swerve drive, hope it will be much better then a mecanum wheel robot, cuz if it doesn't then so much will go down the drain...
FRC Team 2230 - Student - 2009-2011
FRC Team 2230 & 4406 - Mentor - 2012
FRC Team 2230 - Mentor - 2013-present
"A mentor's job is to understand what the students are trying to make, and bend the laws of physics to make that happen"
Unread 22-01-2010, 15:56
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
cool, we are using a tank drive belt, all i can say is that it turns on a dime and climbs the bumb.
Every day is a new adventure!!!
Unread 22-01-2010, 16:06
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
2 questions:
1> Will the mechanums work if you don't hit the bump square?
2> Will that setup work with the bumpers (it looks close)?
___________________
- Tennyson, Ulysses
Unread 26-01-2010, 15:44
kylelanman's Avatar
Programming Mentor
AKA: Kyle
Originally Posted by Daniel_LaFleur View Post
2 questions:
We have not tried it. If it is not perfectly square then it swings around before the climbing motion starts.
According to our drawings and dimensions, Yes.
When you say vertically are you referring to parking on the peak and then driving sideways across the bump? If that is what you mean then yes it works to do that.
Unread 26-01-2010, 16:06
the man's Avatar
AKA: Jacob Overla
FRC #4004
I lied it only climbs the bump if the weight is on the front
Unread 28-01-2010, 07:40
Tony.Wu Tony.Wu is offline
Carnassial
AKA: Dave The Mechanic
Team Role: Animator
Tony.Wu is an unknown quantity at this point
Send a message via MSN to Tony.Wu
what's up with the sloped top?
Unread 28-01-2010, 13:32
ParkerB's Avatar
ParkerB ParkerB is offline
FRC #1225
ParkerB is an unknown quantity at this point
We were going to go with tank treads on our robot but the other vet (hito) and I said it was a bad idea, every time we have seen them used in precious competitions and every time they try to turn the robot looks like its having a seizure..... How does yours turn, "the man"?
The macanum wheels we've been looking into as well... but decided against with this years challenge, I guess we could have gone with them anyway.. Oh well, these things happen!
When I am not doing all this robotics stuff ... I'm doing psychology .... how on earth do I put the two together?!
Unread 28-01-2010, 14:20
fordchrist675's Avatar
fordchrist675 fordchrist675 is offline
"Wilfordito"
AKA: Wilford Jay Harris III
FRC #0675 (Technology High School Robotics)
fordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to all
Send a message via AIM to fordchrist675 Send a message via MSN to fordchrist675 Send a message via Yahoo to fordchrist675
What are you robot dimensions, more specifically what is teh amount of space between each wheel?
It's not by how much you win, it's how you win. Respect your enemies, otherwise your no better than them which if you think about it that's true because we are striving for the same thing. To be FIRST
2010 SVR Creativity Award
2010 SVR Regional Finalists
2010 SAC Innovation in Control Award
Unread 29-01-2010, 16:36
kylelanman's Avatar
Programming Mentor
AKA: Kyle
We just threw our controls/electronics on a sheet of wood and zip tied it to the frame. We will have the controls mounted more permanently inside the robot by the time it is done. It is it an angle currently because the top of our kicker is present in the front of the robot but not the back of the robot.
I haven't got a clue.... The frame is near max size. The actual spacing of the wheels was determined by a student in Inventor. I'm a previous student and am technically a programming mentor. I had a phone with internet so I posted the video. If you want the exact dimensions I can find out and let you know.
Unread 29-01-2010, 16:49
"Wilfordito"
I would very much appreciate that, because I'm curious to see how well our teams robot will do that, and I'd like to just compare robots
Unread 30-01-2010, 18:06
dag0620 dag0620 is offline
Because we're FiNE
AKA: David Givens
FRC #1071 (Team MAX)
dag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond repute
Cool. Team 1071 is also using Mechanim wheels. While we have had allot of issues with the initial programming, once we got the bugs out we had no issues. I love working with them, and the feel of driving is incredible. Be weary though, without proper wait balancing and with poor driving, you will see some flipping of your robot, DAMAGING UR ELECTRONICS!
David Givens
Alumnus Team Max 1071 ('13) | FIRST Volunteer | NE FIRST
Away making magic for a bit...
Unread 02-02-2010, 00:53
kylelanman's Avatar
Programming Mentor
AKA: Kyle
I'm told the the centers of the wheels are 26.5 inches apart from each other.
Holonomic drive vi with mecanum wheels dwodrich NI LabVIEW 7 18-01-2010 16:01
Over the bump or under the tower quinxorin Rules/Strategy 44 18-01-2010 14:17
Help with mecanum wheels CyDrive Programming 7 10-02-2008 16:16
Assistance with Mecanum Wheels CollmandosGrl General Forum 8 14-01-2008 17:42
Teams With Mecanum Wheels Foss@Team176 Technical Discussion 15 06-10-2005 09:38
