Go to Post Just like it is not all about the robots, it is not all about winning the Chairman's Award. - Paul Copioli [more]
Unread 21-01-2010, 10:38
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Any way to speed up the camera feed fps?
We have managed to get the camera feed on to the netbook, and we have noticed that its framerate is VERY low. We know its not the camera because when we view it using its IP adress, it displays at a regular frame rate. Is there anything we can do to speed it up?
Unread 21-01-2010, 11:35
Delian Delian is offline
FRC #3006
Delian is on a distinguished road
Re: Any way to speed up the camera feed fps?
This is a bit of a silly solution, but our Team, team 3006 logged into the developer account on the Classmate, and loaded the Dashboard. When you open up the Dashboard in the Developer state, it opens it as two windows, as long as you keep the lower window, the one with diagnostics, setup, etc., selected, then the frame rate is great.
If someone has a smart solution to this, please respond
Unread 21-01-2010, 14:25
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
This is something I picked up on last year...
Lower the resolution for the camera. It's able to have a better throughput through all the stuff it has to go through before showing up on the screen.
Quality won't be as great, but it did work last year.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 21-01-2010, 14:33
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
If you are using C++, there is an AxisCamera class member function called writeCompression that should allow you to set the level of compression. I'm not sure what value it takes though...it could either be 0 to 100 or 0 to 1 (or something else). The function takes an integer. Does anyone know what values are legal?
- Bryce
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
Unread 21-01-2010, 15:10
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
- Bryce
why would a value NOT be leagal? the best compression range is 20-80
Watchdog.Kill();
Unread 21-01-2010, 15:29
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
- Bryce
Legal as in game legal? I haven't seen any rules prohibiting compression of the data from the source (Camera) and then uncompressing it at the target (classmate).
Legal as in compression legal? 0 to 100 (It's a percentage). With black and white images you should be able to compress upwards of 90 and still have a definable edge to track on.
Remember that MJPEG is a lossy and any compression loses some of the crispness of the picture. You should test your compression to ensure that it does not affect your tracking (in different lighting as well).
___________________
- Tennyson, Ulysses
Unread 21-01-2010, 15:36
Nadav Zingerman Nadav Zingerman is offline
FRC #2230
Nadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to behold
I think he means legal software-wise, not Game-Manual-wise
Unread 21-01-2010, 15:56
Bryscus's Avatar
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Yes, legal software-wise. For instance, if the camera is looking to receive a value between 1 and 100 then 200 would not be a legal value. If the code was not written with the proper error checking who knows what would happen. Apparently legal was not the best term to use when dealing with a game with so many rules.
I would assume that because the GUI interface for the camera allows a setting between 1 and 100 that the writeCompression function would also use these values.
- Bryce
Unread 21-01-2010, 18:00
Sean Raia's Avatar
our resolution is at the lowest we can get it. I will try Delians idea.
Unread 22-01-2010, 16:42
Bryscus's Avatar
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
I think that Delian's idea might be a quick solution, but it's probably not legal during competition.
- Bryce
Unread 22-01-2010, 22:31
From posts on other threads, it seem that some teams are using Fast User Switch to run both the developer and driver accounts. Running the tools and the DS in the different accounts seems to have slow screen updates.
A better approach seems to be to run all of the programs under the developer account. Run the dev tool and then run the driver station from the Start menu.
Greg McKaskle
Speed of the camera nickmagus Programming 86 20-02-2009 21:40
Can we use Hot Glue on the robot in any way?? Leo 1529 Technical Discussion 11 10-02-2006 17:29
camera panning the oppsite way TheHolyLancer Programming 3 04-02-2006 13:53
Any way to see all of the reputation I recieved? Elgin Clock CD Forum Support 8 21-07-2004 12:32
Need way to fix power feed on OI Shu Song Electrical 11 25-04-2004 15:03
