Go to Post when answering a question you throw out other teams names (thunder chickens and killer bees)...and a distinguished guest raises his hand and asks if he heard right when I said thunder chickens and asks for an explanation of what a thunder chicken is. - Devon27 [more]
Unread 22-01-2010, 18:25
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Re: Restrainting pin question
It is not advisable to use the piston rod as a direct mechanism. It should operate a mechanism that will take the load instead.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
RC +5V Pin Voltage adam2177 Electrical 6 18-02-2008 13:07
Tx/Rx pin layout? EHaskins FIRST Tech Challenge 1 27-02-2006 10:18
Pin Trading Astronouth7303 Chit-Chat 12 14-05-2004 14:20
Dutch Pin patrickrd Technical Discussion 5 03-03-2002 12:27
using set screw or dowel pin/pin to hold on drill motor coupler thinggy Travis Covington Motors 1 04-02-2002 03:02
