No Robot Communications
I've been trying to run a standard drive program on my team's robot, but for some reason I'm not able to run the code. I get the error "Failed to connect to Real-Time Target.'
I've updated the driver station and re-imaged the cRIO but nothing has worked. All the wiring is correct, but I just can't establish a connection between the netbook and the cRIO. any ideas? |
Re: No Robot Communications
Have you gone thru the bench top test?
http://www.usfirst.org/roboticsprogr....aspx?id=10934 Get all the way through chapter 2 and 99% of your questions could be answered. |
| cRIO communications problem | alex42 | FRC Control System | 5 | 16-01-2010 20:22 |
| Team Communications | wrenauld | Rules/Strategy | 5 | 24-01-2007 14:01 |
| Serial Communications | 6600gt | Programming | 14 | 28-06-2006 23:24 |
| Timer 0/Serial Communications? | steven114 | Programming | 2 | 13-02-2005 20:50 |
| Radio Communications... | Dan 550 | General Forum | 9 | 29-12-2001 17:00 |
