Go to Post Chief Delphi is special. ... Self-police please. - PayneTrain [more]
Unread 22-01-2010, 18:41
silv940's Avatar
silv940 silv940 is offline
AKA: Sam Wilkins
FRC #1572 (Hammer Heads)
silv940 is an unknown quantity at this point
Send a message via AIM to silv940 Send a message via Yahoo to silv940
Re: Anderson power pole connectors
Powerwerx seems to have the best deal if your buying a lot. Buy the 30 amp sets that include both red and black. Then buy tons of contacts since you can reuse the housings. You can also get the SB-50 connectors for the batteries there.
Unread 25-01-2010, 16:51
Mike9966's Avatar
Mike9966 Mike9966 is offline
Mentor Mike
FRC #2846 (Fire Bears)
Mike9966 is an unknown quantity at this point
Hi all,
Powerwerx is a good place to get them. You can also buy them from westmountainradio.com.
Get the crimper, it works well.
As far as the little hole goes, one can put a metal pin in there to keep the 2 halves from sliding apart, but most people don't recommend it. If the pin falls out it can short things out and that is, well, BAD.
If you want to put something in there you can use a toothpick, or just do what I do. Since you always want the red and black to be a pair, and in the same order, just put a drop of super glue on the little dovetail channel, and quickly slide them together. They will never come apart unless you have much bigger problems. lol
This site, http://www.qsl.net/w2vtm/powerpole.html, has a great picture of how to do it, just DONT put the metal pin in like they show.
We just put them on the Jag's as a pig tail and on the motor as a pig tail and then plug them together. It makes it great to be able to remove your whole electrical board with 4 screws and 5 connectors.
Great for taking it off while the mech team gets metal filings all over everything drilling holes and what not.
Take a look at the 2 places mentioned if you want to mount them in a bracket, they have them.
Good luck
Mike
Do the best you can! Always
Go FireBears
2009 10000 Lakes Finalists, thanks 2825 & 2177
2010 10000 Lakes quarter finalists
2011 Duluth and 10000 Lakes
2012 Superior, and 10K Lakes, Qt finals, MRI
2013 Northern lights, 10K Lakes-Semi finalists, MRI, River Rendezvous, Minne Mini
2014 Northern Lights, 10K Lakes
Unread 25-01-2010, 19:59
purduephotog purduephotog is offline
Active Defense Design Engineer
AKA: Jason
FRC #3015
purduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the rough
Send a message via AIM to purduephotog
Originally Posted by Bochek View Post
Any suggestions on the best place to buy Anderson PowerPole connectors? i need them in 12awg wire size.
Thanks
- Bochek
I have a great place- I found them at a forklift company. They're the cheapest I've seen, you can get them in multiple colours, and you can get all the wire you need too- crimps and otherwise- for what have been the lowest prices.
http://www.helmarparts.com/
In fact, when they were sold out they called me up to talk about the order. That's service.
Tell them you're with FIRST- that won't garner you a discount, but it might, with enough people ordering, get us all a discount come next year
http://purduephotog.deviantart.com
Portrait Photography: "I used to say Immortalized in Silver, but now I say Captured and Squeezed by Electrons".
Anderson Powerpole Connectors Kmo Electrical 4 14-01-2008 00:33
Anderson Connectors!!!! cdennisxlx2 Electrical 9 06-03-2006 19:20
Inventor Model: Small Anderson Connectors CraigHickman Inventor 0 31-01-2006 22:55
Shipping w/ Anderson Connectors Sscamatt General Forum 2 20-02-2005 23:59
45 or 75 amp anderson power products connectors to drill motors? Andrew Wyatt Motors 2 20-12-2001 08:00
