Go to Post Looks very well designed. Now where is the "export to reality" button in the CAD software? (I have been looking for it for weeks). - sanddrag [more]
Unread 22-01-2010, 18:53
zaphodp.jensen zaphodp.jensen is offline
Alumni and Mentor of 3130
AKA: Pierce Jensen
FRC #3130 (East Ridge Robotics Ominous Raptors (E.R.R.O.R.'s))
zaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the rough
Fisher Price Gearbox Torque
Does anyone know the torque of the Fisher Price Gearbox?
Unread 22-01-2010, 19:15
Collin Fultz's Avatar
Collin Fultz Collin Fultz is online now
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
Re: Fisher Price Gearbox Torque
Stall torque is listed as 0.45 N-m for the motor.
Collin Fultz
Unread 22-01-2010, 19:16
AKA: Pierce Jensen
For the gearbox, not the motor itself.
Unread 22-01-2010, 19:32
BHS_STopping's Avatar
BHS_STopping BHS_STopping is offline
The Freshman
FRC #0842 (Falcon Robotics)
BHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant futureBHS_STopping has a brilliant future
To find the torque output of a gearbox, multiply the stall torque of the motor by the inverse of the reduction in speed the gearbox provides.
For example, if the FP motor stalls at .45 N*m, and the gearbox provides a reduction of 1/5, multiply .45 by 5 to get the gearbox torque.
[/The Freshman]
Unread 22-01-2010, 20:26
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
A. Last year's gearbox was ~139:1. I haven't taken this years apart to verify yet.
B. This is a great learning opportunity, learning how to do it yourself is going to be the fastest and most reliable route to your answer. Take it apart and count the teeth.
Stage Gear Ratio = Driven Gear / Driving Gear
Multiply the 4 Stage Gear Ratios of the FP trans to get the overall ratio.
The white paper at http://www.chiefdelphi.com/media/papers/2284 should provide some guidance for getting the gearboxes apart and such.
C. 0.45 N*m is the torque for stall at 70A, don't plan on having that much torque available for any length of time. You can scale it to the 30A torque by multiplying 0.45 N*m by 30A / 70A. There are numerous white papers on this subject.
D. When you get it figured out, post it back here.
Mark
Brick walls are for other people. - Randy Pausch
Unread 24-01-2010, 14:50
AKA: Pierce Jensen
The gearbox ratio is approximately 125:1.
This would put the F-P motor with gearbox at around 41.5 ft/lbs. Unless I'm crazy. . .
Unread 24-01-2010, 19:04
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Nope, that would be the stall torque of the motor/gearbox assembly. You don't really want to stall the Fisher-Price motor however, it will quickly go up in smoke.
In FRC applications, half of stall torque is usually a good number to design around. You can use the sheet here to figure out how fast the motor spins at that torque.
Unread 24-01-2010, 20:16
kramarczyk's Avatar
How did you come up with this number?
Mark
Unread 24-01-2010, 20:17
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
He opened up the gearbox and counted the teeth. My team mentors/shares a shop with his and I saw him hard at work counting teeth.
Unread 24-01-2010, 20:45
kramarczyk's Avatar
Awesome! I just came up with a slightly different number, 122:1. Attached is my counting work from this evening for comparison.
Mark
Unread 25-01-2010, 09:57
Andy A. Andy A. is offline
Getting old
FRC #0095
An exact ratio isn't very important for most FIRST applications. There are a lot of factors in play that make those pristine speed/torque calculations only a rough suggestion. You won't get either the speed or torque that you expect due to frictional losses, voltage drop during a match, manufacturing inconsistencies, directional bias etc. By all means, do the math and use it to design with, but always include a healthy skepticism about your numbers.
I've just used 128:1 in the past to make the math a little easier. I think we arrived at that number many years ago by hooking the motor and gearbox combo up to a charged battery and counting the number of Revs of the output shaft observed in 30 seconds. Then compared that to the specified no-load RPM and rounded off.
Unread 25-01-2010, 11:01
kramarczyk's Avatar
I am not disagreeing that a buffer is required to accommodate variation. How much depends on what you are trying to do.
I am curious if we have the same gearbox with the rumbling about different motor pinions that I have heard. At least one team claims to have received two different gearboxes in the same KoP.
In past seasons I have heard the FP gearbox provided anywhere from 122:1 to 144:1 so I was trying to take the additional steps to back up the numbers provided by including the spreadsheet.
Mark
Unread 25-01-2010, 12:45
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
speed is something you can apply a ratio to and get the right answer (a motor spinning at 15000 RPM will have an output speed of 3000RPM after a 5:1 reduction), but torque does not work that way. You need to apply an efficiency factor to the gearset.
I typically use 90-95% PER STAGE for straight spur gear pairs if things are designed right.
I use 85% (again per stage) for planetary gearsets if the ratio for that stage is below 7:1. The efficiency of a planetary gearset falls off sharply with higher ratios so use multiple stages rather than 1 high ratio stage (2 4:1 stages are MUCH more efficient than 1 16:1 stage).
Helical and bevel gears can be much lower than spur gears but they can be pretty close as well, it all depends on how the thrust loads are managed.
Worm gears? Count on 50% is the best you'll get. Many are are 10-20% efficient (i.e. you have to put in 5X to 10X the amount of power into the gearbox as you get out of it).
You really need to keep in mind the "effective" ratio when thinking about torque and gearboxes. A 110:1 gearbox that gets the ratio in 3 spur gear stages will have an effective ratio of between 80 and 95 to 1 depending on the efficiency per stage.
Joe J.
Team #88, TJ2
Fisher Price Gearbox? excel2474 Technical Discussion 10 12-01-2009 21:14
Fisher Price Torque Halo4life Motors 1 25-01-2008 15:35
Fisher Price Gearbox nreynolds General Forum 23 22-01-2008 13:18
Fisher-Price Gearbox? Aaron Motors 4 17-02-2004 17:41
Fisher Price gearbox Manoel Motors 0 14-02-2003 16:06
