Go to Post They hit us, we hit them, it happens. Build your robots to take a hit and it doesn't matter. - Greg Needel [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 21-01-2010, 21:42
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Wierd program behavior with LabVIEW and 2CAN
We successfully installed the 2CAN, loaded the firmware, found a Jaguar and downloaded version 86 of the firmware to it. On the browser, we could see the voltage and temperature.
However, when we downloaded the Voltage Mode example.vi, it would download, run for a second, then stop with error -52010.
Any suggestions?
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 21-01-2010, 23:07
Re: Wierd program behavior with LabVIEW and 2CAN
That error means a cRIO "requested resource must be initialized before use."
I still have to make my CAN cables before I can help more.
Unread 21-01-2010, 23:28
Jon236's Avatar
AKA: Jon Mittelman
Ok....still looking around for my bootstraps.
Jon Mittelman
Unread 22-01-2010, 18:40
Jon236's Avatar
AKA: Jon Mittelman
Looking at deployment errors: "Failed to load FRC2CANPlugIn.out" I have revised the nrt-ini file and copied the .out file to the system subdirectory. My 2CAN still stubbornly blinks red.
Jon Mittelman
Unread 22-01-2010, 19:47
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
I suspect the problem is that FRC_UserProgram isn't imaged in when the cRIO is imaged for labview. Since the 2CAN plugin uses some of the library that's probably why its crashing. Darn, I thought i had removed all references to classes in the library (Nice catch peterjohnson). Expect an update soon.
Omar Zrien
CTRE Software/Firmware Engineer
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
Unread 24-01-2010, 03:25
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
This means that no plugin is loaded.
Unread 24-01-2010, 08:02
Jon236's Avatar
AKA: Jon Mittelman
That makes sense, since the download window states that it 'fails to download FRC_2CANPlugIn.out'....I think Omar is working on that problem.
Jon Mittelman
Unread 01-02-2010, 15:55
ozrien's Avatar
Omar Zrien
AKA: Omar
FYI 2CAN update is now available...
http://www.crosstheroadelectronics.com/2CAN.htm
Details are explained at ...
http://www.chiefdelphi.com/forums/sh...highlight=2can
C and LabView version control with Git Nibbles NI LabVIEW 31 17-01-2010 19:22
help with Compressor and labview Team2883 General Forum 4 28-01-2009 22:18
NI LabVIEW and Data Acquisition Pilot Program 2006 Application Ready! Danny Diaz National Instruments LabVIEW and Data Acquisition 2 18-10-2006 15:55
Wierd search behavior.... Salik Syed Programming 7 23-02-2006 13:12
Wierd error (With edu bot ... Salik Syed Programming 4 09-03-2004 21:34
