Go to Post Needless to say, lots of smoke came out, and I debated using its terrible smell as a deterrent. - Snapshot [more]
Unread 22-01-2010, 20:09
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
Classmate Question: Default Path Location for Driver Dashboard
Quick Question ...
I remember reading somewhere about the default location on the ClassmatePC so you can load your custom dashboard VI when logging in as the DRIVER. To date, we've had to login as DEVELOPER and run it manually.
My CD search came up empty ... and I've perused the PDF's on the FRC site ... but for the life of me I cannot find the doc/link/tips page where I read about it last week.
Could somebody please point me in the right direction? Thx!
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Unread 22-01-2010, 21:58
Re: Classmate Question: Default Path Location for Driver Dashboard
The location of the dashboard is c:\Program Files\FRC Dashboard\Dashboard.exe. If you need to change the path further, you can modify the ini file in the shared documents directory.
Greg McKaskle
Unread 25-01-2010, 11:53
SteveD SteveD is offline
FRC #0888
SteveD is an unknown quantity at this point
how do you change the dashboard vi's to an exe? or do you not need to?
Unread 25-01-2010, 13:50
Ziaholic's Avatar
Elec/SW Mentor
AKA: Marc
You need to "BUILD" the dashboard project, and then take the resulting EXE file, rename it, and place it in the directory noted above.
I looked ALL OVER for the build button while in the dashboard project, and finally found it, I think, by right-clicking on the VI from the project view window.
(if I remember correctly)
Unread 25-01-2010, 13:56
Expand build specifications, and right click on the dashboard build specification and choose build.
Dashboard not appearing on classmate railerobotics Programming 2 20-01-2010 15:42
Driver Station Dashboard Problems CVassos Programming 9 16-01-2010 23:27
Default Labview Dashboard and Windriver Example Help sircedric4 Programming 7 25-02-2009 01:58
Help with connecting default dashboard project mminutto NI LabVIEW 2 30-01-2009 15:26
Driver Question for stacking clean399 Rules/Strategy 4 27-01-2007 21:44
