Go to Post I think it's great the way people involved in FIRST always try so hard not to argue. It's a good sign that all the talk of Gracious Professionalism is working. - BaldwinNYRookie [more]
Unread 22-01-2010, 20:59
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Re: cRIO random connection failure
Thanks for your help. Unplugging and plugging the cRIO back in works for us too.
Unread 22-01-2010, 21:40
The boot order does seem to provoke an issue, and we are investigating it. It appears to be an issue with how the game adapter/bridge computes its routing table. In the meantime, the warm reboot of the cRIO will correct the issue.
Greg McKaskle
Unread 23-01-2010, 05:38
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Please see the explanation of the issue and resolution here: http://www.chiefdelphi.com/forums/sh...071#post905071
Windriver connection to cRio avolkov Programming 6 05-05-2009 08:40
cRio keeps on staying red on the lab view connection test bio hazard Programming 1 14-02-2009 19:45
Connection with cRIO nadavsen2 Programming 4 29-01-2009 03:13
cRIO configuration issue- serial connection to laptop Torbots 1197 FRC Control System 5 28-01-2009 22:28
cRio losing connection when "run as startup" mgurgol Programming 2 12-01-2009 12:18
