| Thread Tools |
Rating:
Display Modes |
Can ping CRIO and bridge, but DS shows no comm and no code
We are having a weird problem with communicating to the robot using wireless.
First, we were able to re-image the crio and had it running basic code with a kit bot using a tether. The updated drive station is working properly and image is showing up good while using a tether. The problem is with the wireless communication. All the wireless components seems to be communicating properly. I am able to log onto the wireless bridge using IE and get to the 10.xx.xx.1 IP. Same with the router....which is using 10.xx.xx.4. The classmate PC is set to 10.xx.xx.5. Pinging the cRIO is also good at 10.xx.xx.2. Note that on the driver station, all the above mentioned components are green (meaning getting a ping response). That was done all using wireless from router to bridge, but wired connection from classmate PC to router. But the problem is that the DS is still showing "no communication" and "no code". The robot can not be enabled (not even to run the default code that was set to run at start-up) because of the no communication problem. The weird part is that we were able to deploy code to the cRIO using the classmate PC (using wireless). We have reset the bridge and router multiple times and re-did the setup just as many times. Still not working properly. More details: The bridge is set to run at 2.4Ghz as per the instructions for the 160 router. Any ideas on what the problem could be? Thanks! Barry Last edited by Green2 : 01-21-2010 at 11:43 PM. |
Re: Can ping CRIO and bridge, but DS shows no comm and no code
If the ping lights are green, but the communications light is red, that indicates that the communications task on the cRIO is not responding as it should. This most likely means that it is the wrong version. Check the diagnostics page to see if the cRIO is v19, and update if not.
Greg McKaskle |
Also I have had a problem where the cRIO boots up before the bridge and then doesn't find it. This results in the cRIO timing out. Press the little reset button on the cRIO with a small screwdriver or a paperclip. This should turn off and back on the cRIO without turning off the board and then it looking for the bridge and all 3 lights should go green.
Thanks for the reply guys. Problem resolved by turning off the windows firewall.
Just for future reference...it appears that you have to turn off wireless and the windows firewall in order for the cRIO to connect properly. Barry |
| Code deploys but does not save to cRIO | Bill Taylor | NI LabVIEW | 11 | 02-15-2012 08:30 PM |
| Default windriver program, no code and warnings on CRIO console out | pafwl | C/C++ | 1 | 01-16-2010 04:03 PM |
| cRIO Does Not Communicate, Yet Can Be Pinged and Re-Imaged | 1951-44U | FRC Control System | 7 | 12-15-2009 09:25 PM |
| Can not connect bridge and router wirelessly | team877 | Programming | 4 | 01-08-2009 12:18 AM |
