| Thread Tools |
Rating:
Display Modes |
#46
Re: Robot Lifting
IMO, any reasonable drive system will be able to handle that without issue. We're going to see a lot of systems that cannot, regrettably. It would be best to have the ability to get up no matter what area is open.
#47
Re: Robot Lifting
we are currently thinking of some sort of arm idea with a winch assist. The arm alone will not be strong enough to pull us up, so the hook/clip we use will have a pulley system and we will winch ourselves up. The arm isfor getting to the pole first.
#48
Re: Robot Lifting
A well designed drive-train should have no problems.... |
#49
Re: Robot Lifting
Here's a thought. Instead of trying to lift the bot from the very top bar, try lifting it from one of the side bars. It eliminates the possibility that you will get stuck in the tunnels while trying to lift up in the center. The only problem with this idea is the possibility of going side-to-side but with a world of engineers we can solve that.
#50
Re: Robot Lifting
I think you might be underestimating the difficulty of this task by just a little. Atleast if you're thinking of taking it straight on, straddling the bump. Consider: If the bump was a 13.5" plateau as wide as your robot, you'd have a 7.5" vertical cliff in front of you to scale. A cliff of Teflon-like UHMW Polyethylene. Climbing it dead on is possible, but you'll need pretty sticky wheels to get enough purchase to get your front wheels up. Of course, the bump's top isn't as wide as your robot. It's only 12" wide, so unless the inside of your wheelbase is 12", you'll actually start even lower and have an even taller cliff. Specifically, you'll have an inch more to climb for every two inches your wheelbase is over 12. Given that your bumpers start at a max of 11", the widest the inside of your wheelbase can be is 19". So all your reasonable drivetrain designers should keep their wheelbases reasonably narrow and resist the natural urge to make them wide. So, I think climbing the platform straight on from the side is not something you can pull off with just a thrown together drivetrain. Now, I'll admit I haven't had a chance to look at how a bot could use the 45 of the bump to its advantage to get wheels on the top of the platform. It's possible that the correct approach vector will make the climb pretty easy for a multiwheel, very low CoM robot. Well, relatively easy, at any rate. I think you're pretty much certain to be pivot on 2 wheels for a fair amount of time during the attempt. Which is probably survivable for a multiwheel, low CoM robot. Which, unfortunately, doesn't sound quite like any reasonable drivetrain. Last edited by Kevin Sevcik : 21-01-2010 at 23:58. Reason: Erm, what squirrel said |
#51
Re: Robot Lifting
Kevin, I wonder if Craig is suggesting that a robot should be able to climb up on the bump next to the platform, then hoist itself up from the horizontal bar that goes over the bump edge of the platform. If so, it make sense.
Driving up the bump, then onto the platform, is not something that many robots will be able to do. |
#52
Re: Robot Lifting
Tonight we lifted one of the mentors with a CIM and a (slightly modified) off the shelf boat winch. We used a dewalt transmission, however, with an additional reduction between the sprockets. It was pretty quick, with no issues.
#53
Re: Robot Lifting
Hanging from the floor is a much larger task than hanging from on a bump, but can be made simpler by using the vertical bars. Kudos to any team that can do a solid proof concept of it. |
#54
Re: Robot Lifting
What was the ratio of the transmission?
#55
Re: Robot Lifting
Re: Robot Lifting
The 11-second minimum is in constant effect. There is no way to get less than 11 seconds according to the algorithm. |
#57
Re: Robot Lifting
Here is the concept we are implementing to clamp a vertical pole.
![]() Once clamped we will winch the back end of the robot up to the pole. Initial tests are encouraging, though we will probably have a safety bar that can catch the platform to avoid sliding. Note the same mechanism that winches the robot also engages the clamp, using the robot weight to tighten the grip. |
#58
Re: Robot Lifting
Re: Robot Lifting
Yes, a simple flip of the winch ratchet releases everything.
Last edited by TubaMorg : 22-01-2010 at 22:50. Reason: I can't read so I answered the wrong question. |
#60
Re: Robot Lifting
| 1070's 2007 Robot Lifting | AznPrincess3089 | Robot Showcase | 8 | 19-03-2007 19:37 |
| Team 192, Robot Lifting Teaser | Joobacca | Robot Showcase | 7 | 02-02-2007 17:46 |
| Lifting one vs. lifting two | jgannon | Rules/Strategy | 1 | 14-01-2007 17:37 |
| robot lifting | doomsdaytank | Rules/Strategy | 2 | 14-01-2003 16:41 |
| Lifting goals | patrickrd | Rules/Strategy | 6 | 17-01-2002 17:58 |
