Go to Post Instead of lowering a team's expectations, let's raise the amount of competitive resources available to them. ;) - artdutra04 [more]
Unread 22-01-2010, 23:04
Re: Mecanum wheels friction coeff- will it work?
Originally Posted by CidTeach View Post
on a prototype we have, we are able to drive fwd,rev and srafe (sp?) sideways. however when we try to do a 360, or even 180 the robot jumps/jitters and barely rotates(<90deg.)
This can happen if you have the wheels swapped. The wheels will try to push toward or away from the center of the robot instead of spinning the robot. If you can turn it by hand without any power applied, you definitely have the wheels swapped.
Unread 23-01-2010, 00:46
Is it my imagination, or are both Figure 2 and Figure 4 in the following link incorrect:
http://www.scipub.org/fulltext/ajas/ajas351831-1835.pdf
( the link appears on AndyMark's page at
http://store.andymark.biz/am-0083.html )
Unread 23-01-2010, 01:28
Figure 4 is definitely wrong. I think that robot would have real difficulty going straight.
Figure 2 might be wrong, or it might just be a bottom view. Since it's showing the force vectors, it actually makes sense to be showing the spot where the wheels contact the floor.
Unread 23-01-2010, 07:53
OK, agreed, if it's bottom view it's OK. If it's top view it's not going to spin in place well. The side vectors will be trying to spin in one direction while the forward/reverse vectors will be trying to spin in the other.
Unread 23-01-2010, 16:23
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
the only mechanum problems we've encountered is that they don't fit into the KOP brackets, but we're already at work on that
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 23-01-2010, 17:52
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
Having done the calculations, and real world testing, Team 1716 has found that the 8" mecanum wheels will successfuly go over the hump. Unfortunatly we did have to modify the KOP wheel brackets. Once that had been accomplished, we had no problems!
Happy Building
-Mcgurky
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 23-01-2010, 19:40
Happy Building
-Mcgurky
Just curious... How are you planning on configuring your operator interface for controlling the mecanum wheels?
e.g.
Joystick1 y-axis controls fwd/rev for all 4 wheels and
Joystick1 x-axis controls right/left slide and
Joystick2 x-axis control right/left spin
OR
Joystick1 y-axis controls fwd/rev for left wheels and
Joystick2 y-axis controls fwd/rev for right wheels and
OR
something else??
Unread 23-01-2010, 21:35
McGurky's Avatar
Geek
AKA: Kyle McGurk
we are using a single 3 Axis Joystick vs. the ones provided in the KOP.
y-Axis=Forward/Reverse
x-Axis=Left/Right
"z"-Axis=Spin Left/Right
We are using a Joystick similar to this in which you can spin the joystick left and right.
Hope this helps!
-McGurky
Ultrasonics: Will it work and how to make it work DavidB Electrical 2 17-01-2009 16:27
Coefficient of Friction of the slick wheels Michael Leicht Technical Discussion 1 07-01-2009 13:08
How Do Mecanum Wheels Work? SPARKY1688 Kit & Additional Hardware 9 08-01-2007 23:39
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Mecanum Wheels chaolin2007 Control System 1 25-02-2006 19:16
