Go to Post Mentors learn from, are inspired by, and emulate each other. A team with a great lead mentor leads to a productive, inspired, and ultimately successful group of mentors. - Jared Russell [more]
Unread 22-01-2010, 23:42
joxphoto joxphoto is offline
FRC #0369
joxphoto is an unknown quantity at this point
Sample 2010 C++ Program's Autonomous Not Won't Run
Hello everybody--
I tried to run the 2010 C++ Sample program using Wind River - as is.
The code for Autonomous isn't running. I would like to find out from you whether you have experienced the same, and what do we need to do in order to make it functional?
Please help, thanks!
Unread 25-01-2010, 11:22
EagleS!! EagleS!! is offline
FRC #3390 (Anatolian Eaglebots)
EagleS!! will become famous soon enoughEagleS!! will become famous soon enough
Re: Sample 2010 C++ Program's Autonomous Not Won't Run
Originally Posted by joxphoto View Post
Hello everybody--
I had the same problem, the code didn't run. Maybe it happened because we didn't make it right but I can't figure out the problem. Then my friend and I decided to use LabVIEW. It works
Unread 25-01-2010, 13:30
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
I need to see my coding to remember exactly what I did, but I changed some numbers and it started working for me!! The only problem I found out after that was I couldn't get the robot out of Autonomus without restarting the robot. If I get a chance today at our team's meeting I'll post what I did, otherwise I'll just post again tomorrow.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
2010 Sample Camera Code MHSrobotics2853 NI LabVIEW 6 17-01-2010 21:10
User code won't download/run-possible causes? nathanww C/C++ 3 21-01-2009 11:00
Forcing autonomous to run Tim Arnold Programming 2 05-04-2007 20:40
Sample Autonomous Modes NextPerception Programming 9 03-01-2007 17:26
pic: Autonomous Control Sample Squall Extra Discussion 4 07-04-2005 01:53
