Go to Post If only every team had a Wildstang programmer! - Jeremiah Johnson [more]
Unread 20-01-2010, 17:51
peter1626 peter1626 is offline
FRC #1626 (Falcon Robotics)
peter1626 is an unknown quantity at this point
Help with pneumatics wiring
We are trying to use pneumatics this year however we are having trouble with the wiring. We have already looked at the wiring diagrams for this year and last year and are still unable to wire it correctly. Does any know where we can find other instructions or real pictures of how to wire the pneumatics?
Thanks for the help!
Peter
Unread 20-01-2010, 18:50
WGRAY WGRAY is offline
FRC #2027
WGRAY is an unknown quantity at this point
Re: Help with pneumatics wiring
Using labview 8.6 go to examples, compressor with cylinder. Open this example and go to the front panel of compressor with cylinder vi. You can leave out the limit switch, or not.
Unread 20-01-2010, 20:51
Thanks! I will try this tomorow and let you know if it works.
Unread 21-01-2010, 14:42
The labview diagram did not work I rewired the whole thing several times and ran the code with no success.I have still been unable to get the compressor to turn on. If I attach the compressor directly to the battery and pressurize the system then hit the maual buttons on the solinoid it extends and retracts but i cant cant ANYTHING to work with code!
Unread 21-01-2010, 14:44
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Did you enable the cRio with the Driver's Station?
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 21-01-2010, 15:00
Im guessing I didnt do this since I have no clue what your talking about. How would one go about enabling the cRIO with the Driver's Station?
Unread 21-01-2010, 20:19
The cRIO won't execute user code unless it's in communication with your Driver Station (and the E-stop button is connected to your Driver station).
And you enable the cRIO with a big clickable button on the Driver station or F1.
Unread 22-01-2010, 21:15
There is no
in labview while RUNNING a code. We are not trying to BUILD and DEPLOY so it runs when you quit labview and save code to the cRIO. We are simply running a code with labview, last year you were able to run a labview .vi right from the computer. Can you still do this? If so how?
Unread 23-01-2010, 00:12
  1. Push the LabVIEW Run button
  2. Start the Driver Station from Windows Start -> Programs
  3. Push the button labeled "Enable"
Unread 24-01-2010, 16:26
Thanks Mark
It works now!
Unread 24-01-2010, 16:36
See you at Long Island soon!
Help with photoeye sensor wiring John.McInerney Sensors 0 22-01-2009 18:03
Help with Wiring diesel Electrical 0 16-02-2008 12:42
NEED HELP WITH uncontrollable pneumatics Tds123 Pneumatics 6 11-02-2008 04:34
Need help with Wiring greendog99 Electrical 6 06-02-2008 17:01
Need Help With General Pneumatics Ryan O Programming 7 24-01-2007 21:31
