Go to Post I have a feeling this is going to be a really good year.:) - Richard Wallace [more]
Unread 20-01-2010, 17:37
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
kicker idea input
Hi, I've seen many different kickers all over the place, however I wanted to create a thread that tries to gather the ideas for kickers in a single spot.
We're attempting to do a kicker using pnuematics that has adjustable range for gaol kick, midfield kick, and farfield kick. One idea we have is to have three pressure settings. I guess that would mean either an adjustable regulator or three different pressure lines leading to a single cylinder in which depending on the type of kick a different solenoid valve would actuate.
I guess one thing I havent quite figured out is how to make sure that the solenoids will not conflict with each other in controlling the cylinder.
Any ideas?
Also, this is a thread for all kicker designs! If any of you have other ideas that are better such as spring loaded kickers controlled by cams attached to motors please feel free to share!
Unread 20-01-2010, 17:47
dude__hi's Avatar
dude__hi dude__hi is offline
Now a CSWA
AKA: Cristian Arcega
FRC #0842 (Falcon Robotics)
dude__hi is an unknown quantity at this point
Re: kicker idea input
We unintentionally had short kicks a few years ago by lowering the amount of time the solenoid opened the valve.
Powerpoint is a distraction, people use it when they don't know what to say...
2008 FIRST Chairman's Award Winner
Unread 20-01-2010, 18:15
jhaugen jhaugen is offline
J. Haugen
FRC #0842 (Carl Hayden Falcons)
jhaugen is an unknown quantity at this point
That's the approach we are looking at as well.
Unread 20-01-2010, 19:09
zephyrnaut's Avatar
zephyrnaut zephyrnaut is offline
aka Chocolate Thunder
AKA: Brandon
FRC #2638 (Rebels)
zephyrnaut is an unknown quantity at this point
a model we are using, which we saw in a video, uses surgical tubing to create a sort of sling-shot like bar.
Unread 20-01-2010, 19:27
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
If it's the one that I'm thinking of, then we're checking out that video, too. There's another video that combined surgical tubing AND pneumatics, which has an interesting approach.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 20-01-2010, 19:33
Rick Wagner's Avatar
Rick Wagner Rick Wagner is offline
FRC #3008 (Kalani Robotics)
Rick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to beholdRick Wagner is a splendid one to behold
My team prototyped several pneumatics kickers, with and without leverage, and couldn't get enough power, even with a two inch bore cylinder, so we are going to surgical tubing and pulling the kicker back with a motor. Not sure yet how we will trigger it.
Unread 20-01-2010, 21:30
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
the leg seems like a good idea
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 20-01-2010, 21:36
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
Our main prototype was a regular hammer attached to a CIM. I can tell you that it is important to have a weight on the end of your swinging arm, because the formula we use is momentum or M(kicker) * V(kicker) = M(ball) * V(ball).
Go REX!!!
Unread 20-01-2010, 21:39
bhsrobotics1671's Avatar
bhsrobotics1671 bhsrobotics1671 is offline
Andrew Nabors
AKA: Andrew Nabors
FRC #1671 (Buchanan Bird Brains)
bhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to beholdbhsrobotics1671 is a splendid one to behold
We are really diggin team #842 designs and videos. They have helped us a lot with their prototypes!
Buchanan Bird Brains - FRC Team 1671
2015 FIRST World Champions
118, 1678, 1671, 5012
Unread 21-01-2010, 02:17
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
We considered pneumatics and ordered our free Bimba cylinders, but then we estimated we could not have enough CFPM flow from the compressor do frequent full-field power kicks without depleting the reserve pressure.
So we opted for CIM powered bungee tension kicking.
A piece of wood 2x4 foot + PVC pipe leg pendulum test showed we could get some decent bungee powered kicks.
We are now testing a sliding PVC pipe ram having kevlar cables attached at rear on both sides and two bungee groups (one for each side of ram) attached to cables.
We plan to pretension the ram so it already has some bungee force on it at the start of the pull stroke. Then a geared down CIM with output of 12-15RPM will give us a 180 degree wind up of cable for ~10 more inches of bungee pull. The winder mechanism is designed to be able to release shots at any point in the wind up, so we can have programmable control of distance. The winder mechanism design can immediately start the pulling for next wind up cycle as soon as it shoots, and we don't have to wait for gearbox to run another 180 degrees before it starts the next pull. We will have enough power to shoot full length of field shots every 2-3 seconds for the entire match. We will also be able to use our kicker winder as a tower winch at end of game, so it is located near bottom center of robot.
More info to follow as we assemble.
-RRLedford
Unread 21-01-2010, 03:11
Eric Schneider Eric Schneider is offline
FRC #2605
Eric Schneider is an unknown quantity at this point
This is true, but the problem is if you are accelerating the kicker, F=ma and if the force being applied by the surgical tubing or spring or whatever stays constant and the weight goes up, it will decrease the acceleration. It's a take some, lose some sort of thing. If you drop your kicker and it is accelerated by gravity, more weight is better.
On the other hand, the longer you give the leg to accelerate (longer swing) the greater the velocity of the kicker. We're thinking of ways to either give the kicker as long a leg as possible or pull it back farther to give it more swing time. This decreases the forces we are playing with a bit and makes it safer, for one. When playing with these coiled or stored forces capable of kicking a ball across the field I'm kinda scared somebody's going to get smacked in the building process. Safety safety safety
Unread 21-01-2010, 03:26
AKA: Dick Ledford
You can look at ways to keep the force at max during the full travel of the kicker's travel. With pneumatics, have a longer cylinder with most of its volume pressurized behind piston at START of kick and also use less travel of piston (more leverage & short stroke).
With bungees, preload tension in them so decent force is still being applied to kicker at end of its travel as well as at start, instead of force being zero at end of travel. Basically do what can be done to maintain full force for the full travel of the kicker.
-RRLedford
Unread 22-01-2010, 20:06
AndrewJS's Avatar
AndrewJS AndrewJS is offline
FRC #2867 (ElkLogics)
AndrewJS is an unknown quantity at this point
That is close but not quite correct. Momentum is conserved, and energy is conserved.
Therefore:
Conservation of Momentum
M(kicker)*V(kicker[before]) = M(Ball)*V(Ball) + M(Kicker)*V'(kicker)
Where V(kicker[after]) is the speed of the kicker after hitting the ball (do not assume this is 0).
Conservation of Energy
KE(kicker[before]) = KE(ball) + KE(Kicker[after]) + Eint
(Where KE = 1/2mv^2 and Where Eint is the internal energy lost to deformation of the ball, I suppose you could include others like heat as well, but I don't see too much heat being created here). I ran an experiment in my garage (bouncing a soccer ball on my cement floor, recording with a camera, and analyzing the height of each bounce) and saw that roughly 60% of the kinetic energy of the soccer ball was lost on each bounce. I have not run equations taking this loss into effect, but my guess is that Eint = .4*KE )
Collisions can be elastic, inelastic or somewhere in between. Elastic means that kinetic energy is completely conserved (Eint in this case would be 0). Inelastic means kinetic energy is not conserved.
For sake of equations, lets assume the collision between a kicker and a soccer ball is completely elastic, so Eint = 0. You can then solve the two above conservation equations (took me a full page) but you get in the end:
V(ball) = 2 * V(kicker) * M(kicker) / ( M(ball) + M(kicker) )
Lets take the case where M(kicker) is much greater than the mass of the ball. Taking a limit as M(kicker) -> inf, Then:
This is the maximum velocity you can ever hope to achieve with the ball (twice that of the kicker). As Walter Lewin (MIT) would say, "very non-intuitive." Nevertheless, don't concentrate on making your kicker too massive. The real key is balancing having enough mass and speed, as mentioned before using F = ma where your kicking force will be constant (if you are using a spring/elastics and pull it back to the same spot each time).
Yet this doesn't take into account the loss of energy due to Eint. You'd have to re-solve all the equations for this. Or, just plan on designing something about twice as powerful as it is in theory.
This is the point where I stopped doing equations (trying to calculate everything was getting quite ridiculous) and just built a kicker prototype, which actually worked quite well at throwing balls across the room and breaking ceiling tiles. We are going with a spring loaded pullback (our prototype used bungee cords) Still working out details for a fast and strong winch to pull it back. Our wish is to have the release be adjustable, this will give use the advantage of selecting how hard we want to hit it. If all else fails, we can use a (probably simpler) system to release it at the same spot every time.
Unread 23-01-2010, 00:32
AKA: Dick Ledford
Team 3135 failed miserably with its RAM kicker accelerated by bungies!
Our PVC pipe ram kicker prototype, with 1-1/4" pipe sliding inside 2" pipe was kicked powerfully ONLY when hitting ball dead center, but could not elevate at that contact spot. The end of pipe had a tee in it to hit ball like a hammerhead shark, but even with good speed, hitting much below center killed all the power delivered. It seemed that too much torque and bending was happening as the 1-1/4 pipe extended much beyond the 2" guide pipe. There was no ram wiggle at all, and it was almost frictionless sliding, but this scheme would not elevate at all. This is the nature of compression - it wants to buckle and bend things out of alignment and initiate torque, whereas tension pulls things into alignment with each other.
So we went back to doing a bungee driven two arm pendulum, building a final scheme with metal parts today, and using ball bearing 5/8 swing axle. Already, we are up to 40 feet airborne without even very much optimization. The pendulum kicker produces elevation of kicks SO much more easily than the ram, and it is far simpler to tune for proper ball contact.
We are still intending to use a CIM+gearbox as a winder for bungee pulling to store energy. The winder sits between kicker and bungees, which all have one of their ends anchored on the frame. Cable passes through winder which can shorten cable by from 0-20" with a 0-180 degree cable wind. Cable can be instantly disengaged from winder - AT ANY # DEGREES INTO THE WIND UP CYCLE - allowing snap back to a straight un-wound state, and variable energy release under programmable controll based on how far the winder is rotated before cable is released. This way we have variable kick energy at programmed levels.
Pneumatics can do too, this using a programmed valve open interval to limit level of pressure build up for shorter kicks.
Our design for the winder's pneumatic trigger mechanism for disengaging cable from winder is being tested using wood on Sat. If all goes well, we will be cutting metal to finish kicker bu Thr. Will post results as we progress.
-RRLEDFORD
Unread 23-01-2010, 00:54
Get rid of the hammerhead tee and replace it with a sloped surface (like a cattle guard on the front of a train). Then you will get lots of lift.
987 Kicker Destruction JM987 General Forum 29 23-01-2010 16:46
Hybrid Kicker falconmaster General Forum 15 20-01-2010 14:27
kicker or linear accelerator? John G Technical Discussion 7 20-01-2010 13:48
2.5 is alive !!!! (input ! .. more input ! ) Lloyd Burns Programming 2 14-01-2003 19:15
New Format - Good Idea/Bad Idea? Harrison Chairman's Award 4 07-11-2002 16:28
