Go to Post Don't just assume that because you can modify an existing design that you are an engineer. - Daniel_LaFleur [more]
Unread 23-01-2010, 11:01
CometGirl977's Avatar
CometGirl977 CometGirl977 is offline
TheCometGirl
AKA: Ashley Sweeney
FRC #0977 (The Cometbots)
CometGirl977 is an unknown quantity at this point
Send a message via Yahoo to CometGirl977
Contradicting Dimensions for Trident
Has anyone else found the contradicting dimensions on the drawings for the trident??? Which ones would be the best to use, 36" or 48"? Need an answer ASAP!
Unread 23-01-2010, 11:05
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Contradicting Dimensions for Trident
Which dimensions on drawing GE-10010.pdf are contradicting?
Or if they contradict some other document, which one is it?
Unread 23-01-2010, 11:07
TheCometGirl
AKA: Ashley Sweeney
It's item 5 (GE - 10011) on sheet one of drawing GE - 10010. One measurment is calling for 48" and the other, one sheet 2, is calling for 36"
Unread 23-01-2010, 11:10
MrForbes's Avatar
AKA: Jim
Look at the top right corner of the first sheet, it has the revision history. It states that revision 1.1 was to shorten the length of item 5.
My guess is that they forgot to change the length in the parts list, but they did change the length on all the drawings. Since it's a scale drawing, you can see that the part is really only 36" long.
You might want to ask on the official Q&A though.
If you make it too long, you can cut it off later. If you make it too short, you can glue on a coupler and another piece of pipe later.
Unread 23-01-2010, 11:12
TheCometGirl
AKA: Ashley Sweeney
Thanks the guys didnt catch that
Unread 23-01-2010, 11:30
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
New dimension question...
G6.2.4 from udate number 3
"The PLATFORM is approximately 41 inches wide by 32 inches deep, and is at a height of approximately 21 inches above the floor. A 36-inch wide by 18-inch tall TUNNEL under the PLATFORM, providing a passageway between the MIDFIELD and the adjacent end ZONES."
Rev B Game Field Specs:
Inside wall = 16 1/2 x 32 1/2
Upright stiffener = 17 x 3 1/2
SO we have built a platform to specs and prototyping team is complaining that platform is 1 inch too short...which is correct, the manual or the specs?
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Unread 23-01-2010, 14:01
GaryVoshol's Avatar
Cogito ergo arbitro
The drawings are the correct measurements:
Originally Posted by Team Update 3
As noted in Section 6.1.1 of The Manual, "the exact dimensions and construction details of the ARENA are contained on the official ARENA drawings." If there are cases where the dimensions in the official drawings and narrative in The Manual are in conflict, please defer to the official drawings.
(since 2004)
Unread 28-02-2010, 13:31
TJ Cawley's Avatar
TJ Cawley TJ Cawley is offline
THE Freshman
FRC #1108 (Panther Robotics)
Team Role: Driver
TJ Cawley is a jewel in the roughTJ Cawley is a jewel in the roughTJ Cawley is a jewel in the roughTJ Cawley is a jewel in the rough
when building the trident for our team, we used the 48" length and when we measured from end to end the length was as the size in the manual was, 6 feet. hope that helps
"To create a world where science and technology are celebrated... Where young people dream of becoming science and technology heroes"-Dean Kamen
This should start each year by focusing on worldwide issues, and having a game that, in theory if not practice, will help fix or compromise a solution with those issues, to make a better, safer worldwide and FIRST community.
Unread 01-03-2010, 16:02
Cynette Cynette is offline
Worry is a poor use of Imagination
AKA: Cynette Cavaliere
FRC #1511 (Rolling Thunder)
Cynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond repute
Send a message via ICQ to Cynette Send a message via AIM to Cynette
And in contrast - we built our according to the drawing and they were 5 ft., which also matched with the size of the trident at kick-off in Manchester, but not with the manual.
Cynette
The best angle from which to approach any problem is the TRYangle
--Chinese Fortune Cookie
Rolling Thunder, Team 1511: The Thunder just keeps getting louder!
Contradicting dimensions? StorminNormin General Forum 30 22-01-2010 17:02
Can trident break field boundary? johnr Rules/Strategy 2 20-01-2010 09:34
Trident Design JJD General Forum 3 16-01-2010 14:38
[OCCRA]: Looking for SPECIFIC Dimensions for the Game field! stk86 OCCRA Q&A 1 28-09-2004 10:46
Looking for SPECIFIC Dimensions for the Game field! stk86 Technical Discussion 0 27-09-2004 15:21
