Go to Post The 48 defensive DNA lies dormant in the drive train. It's impossible to forget. - Koko Ed [more]
Unread 23-01-2010, 11:25
AustinGra AustinGra is offline
FRC #0871
AustinGra is an unknown quantity at this point
How do you wire the ADXL354 Accelerometer?
Can anybody explain how to wire the ADXL345 Accelerometer Board or can someone provide a wiring diagram? Thanks.
Unread 23-01-2010, 12:30
erichahn525 erichahn525 is offline
FRC #0619
erichahn525 is an unknown quantity at this point
Re: How do you wire the ADXL354 Accelerometer?
Because the Accelerometer is a digital sensor, your going to wire it into the digital side car. You're going to preferably solder 4 pins into "OV, SDA, SCL, and 5V" then use female to female wires to connect it to the side car. The pins on the side car are next to the I2C (the small gray box). 5v on accel connects to 5v on side cart, SCl on acel connects to SCL on side cart, SDA connects to SDA on side cart, and finally OV connects to (-) on side cart. I hope all this helps
Unread 23-01-2010, 20:39
DonRotolo's Avatar
Back to humble
FRC #0832
Don't solder to the Digital Sidecar; use a connector.
Details of what connects to where are in the Sensor Manual, found on the FIRST web site.
Unread 11-02-2010, 19:47
PingPongPerson's Avatar
PingPongPerson PingPongPerson is offline
Hardcore Robot Addict
AKA: Michael Groom
FRC #0955 (CV Robotics)
PingPongPerson will become famous soon enough
This was very useful, thanks. Do you also know how to wire the connected gyro? We are stuck trying to figure this out.
Unread 11-02-2010, 23:33
Listen to Don.
How do you wire up the Operator Interface? iPilipino Electrical 6 22-01-2008 00:22
How do you wire the gear tooth sensor? 1594code Electrical 5 12-01-2008 16:24
How do you wire the wheel encoders? Demothesis Electrical 2 17-07-2007 16:59
how do you wire the team light coolguybigt Robot Showcase 2 21-02-2007 22:18
how do you mount the accelerometer? team 507 Control System 4 10-02-2005 07:54
