Go to Post I predict the champion drive teams at each event of the 2011 season will consist of vertebrates. - Taylor [more]
Unread 23-01-2010, 13:29
xionphoenix xionphoenix is offline
FRC #2342
xionphoenix is an unknown quantity at this point
Error in Simple Template
I was recently trying to get throttle code working for our robot and I was using the simple template, even without making any changes to the code It comes up with a build error without any location
the error reads
C:\WindRiver\vxworks-6.3\host\x86-win32\bin\make.exe: *** [SimpleTemplate_partialImage/Debug/Objects/SimpleTemplate/MyRobot.o] Error 127
Build Failed in Project 'SimpleTemplate' (Process Exit Value was 2): 2010-01-23 13:28:58 (Elapsed Time: 00:00)
Location Unknown
*note, the error comes up no matter what changes i do or do not make
please help
thx
Unread 23-01-2010, 13:36
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Re: Error in Simple Template
A wild guess here.
Try closing and then reopening the project in Workbench.
After reopening, make sure you rebuild (not build) the project.
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Unread 23-01-2010, 13:41
FRC #2342
when i try to hit re-build, the selection is grayed out as well as all the other choices in that sub menu
Unread 23-01-2010, 13:45
gvarndell's Avatar
Software Engineer
FRC #1629 (GaCo)
Team Role: Parent
Seems as though your project is hosed -- or maybe your whole installation.
Have you been able to build any projects?
If so, can you create the project again (give it a different name)?
Unread 27-01-2010, 15:18
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Nope, that means you have automatically build selected.
Watchdog.Kill();
Unread 27-01-2010, 16:38
gvarndell's Avatar
Software Engineer
FRC #1629 (GaCo)
Team Role: Parent
I had to ponder this a while just to get to the point where I think I understand what you're saying.
You're saying there's an option somewhere which if selected means you can't build or rebuild a project other than automatically?
If that's correct, where is this option and what does one do to cause an automatic build of the project?
I know Workbench fairly well, don't claim to know everything about it though, and I'd like to understand your reply.
Unread 27-01-2010, 18:48
byteit101's Avatar
When you save it builds.
look on page 9 of http://first.wpi.edu/Images/CMS/Firs...artedWithC.pdf
but disable it instead
Watchdog.Kill();
Unread 27-01-2010, 19:21
gvarndell's Avatar
Software Engineer
FRC #1629 (GaCo)
Team Role: Parent
I have to admit, I never knew that preference existed.
I can see where it might be useful to some folks.
In practice, I think one rarely wants the project to be built every time one saves a file -- unless it's a one source file project.
Nonetheless, useful feature or not, enabling it does not render me unable to rebuild projects by right-clicking the project and selecting rebuild-- I just tried it.
MPLAB error: Error [1027] unable to locate 'serial_ports.h' rokenboker Programming 10 03-09-2009 16:29
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
Template Project Astronouth7303 Programming 10 30-05-2004 20:05
Simple Syntax Error miketwalker Programming 6 06-01-2004 00:17
