Go to Post Its a good bug too. :) - spadercool [more]
Unread 23-01-2010, 13:30
Re: Programming Mecanum
Originally Posted by Daniel Jones View Post
The holonomic drive function will work with either mecanum or with a 4-wheel omni drive if the wheels are oriented 90 degrees from eachother, arranged like this:
on your diagram above for holonomic drive, when using mecanum wheels does it matter which way they are oriented?
Unread 27-01-2010, 18:41
Zrob Zrob is offline
FRC #1631
Zrob is an unknown quantity at this point
Ah, yes it works pretty well, except there's you gotta use
drive.holonomicDrive(leftStick.getMagnitude(), leftStick.getDirectionDegrees(), rightStick.getX());
holonomicDrive takes magnitude first, then direction.
One thing though: There's these weird delays, which I'm attempting to fix.
Unread 29-01-2010, 01:38
Imadapocalypse's Avatar
Imadapocalypse Imadapocalypse is offline
The Walking Contradiction
AKA: Bryce Ribucan
FRC #2443 (Blue Thunder)
Imadapocalypse is an unknown quantity at this point
Send a message via AIM to Imadapocalypse
Okay at this moment our programmers are working on trying to figure out the holonomic drive method. The motors are connected to the correct PWMs and we've been using the exact code given here in the forum but through our misfortune we have came up with the notion that the holonomic drive class has errors. Depending on what we do to our code the wheels will run in opposite directions, forward, or rotate; but never reverse.
We think it has something to do with the order of the parameters. Our programming works better if we put rotation where magnitude goes and vice versa. Direction is still much of a mystery.
As you can probably surmise from this entry our troupe of programmers are confused at this point. Right now our mentor is planning to copy the holonomic drive class in order to play with it to see if that yields any positive results.
The needs of the many out-weigh the needs of the few and the one
Unread 29-01-2010, 13:20
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
Do you need to set the motors on one side inverted? When we first just tried we noticed the wheels on one side were reversed and we needed to add:
setInvertedMotor(RobotDrive.MotorType motor, boolean isInverted)
Unread 15-02-2010, 21:43
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
Can someone please post the java scource code for the holonomicDrive Function?
Unread 16-02-2010, 17:10
AKA: Brad
#0190 ( Gompei and the Herd)
The code is posted below, but anyone with Java can simply look at the source code by opening the project that comes with the distribution:
    public void holonomicDrive(double magnitude, double direction, double rotation) {
        double frontLeftSpeed, rearLeftSpeed, frontRightSpeed, rearRightSpeed;
        magnitude = limit(magnitude);
        double cosD = Math.cos((direction + 45.0) * 3.14159 / 180.0);
        double sinD = Math.cos((direction - 45.0) * 3.14159 / 180.0);
        frontLeftSpeed = limit((sinD * magnitude + rotation));
        rearLeftSpeed = limit((cosD * magnitude + rotation));
        frontRightSpeed = limit((cosD * magnitude - rotation));
        rearRightSpeed = limit((sinD * magnitude - rotation));
        m_frontLeftMotor.set(frontLeftSpeed * m_invertedMotors[MotorType.kFrontLeft_val]);
        m_frontRightMotor.set(frontRightSpeed * m_invertedMotors[MotorType.kFrontRight_val]);
        m_rearLeftMotor.set(rearLeftSpeed * m_invertedMotors[MotorType.kRearLeft_val]);
        m_rearRightMotor.set(rearRightSpeed * m_invertedMotors[MotorType.kRearRight_val]);
Brad Miller
Robotics Resource Center
Mecanum Programming Help Mars Programming 8 27-02-2008 15:41
Bizarre Mecanum Programming Bug manderson5192 Programming 10 08-02-2008 22:11
Mecanum drivetrain programming problems Mr. Freeman Programming 4 21-03-2007 17:11
mecanum programming mrmummert Programming 27 28-01-2007 13:45
programming motors with programming kit BorisTheBlade FIRST Tech Challenge 4 01-11-2005 19:03
