Go to Post If your goal is to win matches... Pick the most capable candidate. If your goal is to change lives... Sometimes you pick those that need the most change. - IKE [more]
Unread 23-01-2010, 13:41
xionphoenix xionphoenix is offline
FRC #2342
xionphoenix is an unknown quantity at this point
Re: Error in Simple Template
when i try to hit re-build, the selection is grayed out as well as all the other choices in that sub menu
MPLAB error: Error [1027] unable to locate 'serial_ports.h' rokenboker Programming 10 03-09-2009 16:29
Error in code light on, trouble finding error Bryan Herbst Programming 16 12-10-2007 21:59
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
Template Project Astronouth7303 Programming 10 30-05-2004 20:05
Simple Syntax Error miketwalker Programming 6 06-01-2004 00:17
