Go to Post Add a little more grease if you aren't sure exactly how much you need. - MrForbes [more]
Unread 23-01-2010, 13:53
Tastybabies Tastybabies is offline
FRC #2040
Tastybabies is an unknown quantity at this point
Animating water
Basically I've been looking for tutorials on animating fluids and have not been able to find any aside from the particle flow one that comes with 3ds max. Could someone refer me to a good one?
Ideally, I'm going to have a seaside scene with waves and a scene with a lake (which will have several objects impact the water). any advice on this would be good.
I did look at the links for the lost page and I didn't see any there.
Unread 23-01-2010, 22:19
adamrw91 adamrw91 is offline
FRC #0701
adamrw91 is on a distinguished road
Re: Animating water
You just gotta do a little bit of googling its pretty easy!
I'd recommend that you use a displace modifier on a pretty high density plane and use a noise map for the displace modifier. Then animate the phase on the noise map. you can then use this tutorial to add a little more detail to the watter surface. http://www.3dtotal.com/team/Tutorial...surface_01.php
Safe Water, Precious Water ebarker Fundraising 1 04-11-2007 18:43
Animating a Bend Rob2713g Inventor 4 21-05-2007 12:28
animating rotation negfrequency Inventor 6 28-12-2006 19:19
Challenge: animating the inanimate JoeXIII'007 VEX 4 22-08-2006 13:55
Trouble Animating Containers Ryan Dognaux 3D Animation and Competition 3 31-01-2003 19:36
