Go to Post We need to celebrate great things because good enough isn't inspiring. - Andrew Schreiber [more]
Unread 23-01-2010, 10:50
scherbs17 scherbs17 is offline
FRC #1756
scherbs17 is an unknown quantity at this point
Kicker mechanism and frame perimeter
Hello all,
After reading and re-reading the rules regarding FRAME PERIMETER, we’re still not 100% sure if we are in compliance with the intent of the rules. Our robot FRAME PERIMETER this year is only 28”x 28”, but our kicker design currently rests partially outside the FRAME PERIMETER (but inside the BUMPER PERIMETER) when the robot is unpowered. During normal operation the kicker will remain retracted until we need to kick the ball and therefore we meet the two rules below (letter of the law type thing). Anyone have any thoughts on this?
<R16> During normal operation no part of the ROBOT shall extend outside the vertical projection of the FRAME PERIMETER, except as permitted by Rule <G30>.
<G30> ROBOT Volume – During a MATCH, no part of the ROBOT shall extend outside the vertical projection of the FRAME PERIMETER, except as follows:
a. BALL Interaction Volume – Solely for the purposes of interacting with a BALL, MECHANISMS that are below the BUMPER may extend up to the BUMPER PERIMETER, for a period not exceeding two seconds. After returning inside the FRAMER PERIMETER, such MECHANISMS are not permitted to re-extend beyond the FRAME PERIMETER for at least two seconds.
Thanks for the help!
Team 1756
Unread 23-01-2010, 10:55
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Kicker mechanism and frame perimeter
It sounds like you'll have to change how your kicker works, perhaps how it resets.
If you post some pictures or drawings we might be able to give you some ideas how.
Unread 23-01-2010, 14:18
KGood's Avatar
KGood KGood is offline
Capt'n
AKA: Kevin
FRC #2134 (Aztec Pirates)
KGood is an unknown quantity at this point
I think the rules are a bit vague about the distance between the frame and bumper perimeter. Just to be safe, I'd move it back those few inches to the inside of the frame.
2007: Rookie All-Star Award
2008: #2 of 54 in AZ Regional
Unread 23-01-2010, 14:55
Originally Posted by scherbs17 View Post
Hello all,
Team 1756
What you describe seems to be in conformance with the rules you quoted. Have you tried posting this question to the "official" Q&A forum at USFIRST to see if you can get a clarification from the GDC? I too would like to hear their answer.
Unread 23-01-2010, 19:22
GaryVoshol's Avatar
Cogito ergo arbitro
You quoted the rule. Your kicker mechanism can only extend beyond the FRAME PERIMETER for 2 seconds at a time, and then must retract. Resting outside the FRAME PERIMETER would not be allowed.
(since 2004)
Unread 23-01-2010, 19:32
The OP said it rests outside the FRAME PERIMETER *only when the robot is not powered*. During normal operation it rests inside the FRAME PERIMETER. The GDC will probably rule against it, but there is some room for doubt here.
Unread 23-01-2010, 19:34
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
Hello all,
Team 1756
I think the safe bet if your kicker works well is just make a larger frame perimeter so you don't have this issue.
Unread 24-01-2010, 07:24
GaryVoshol's Avatar
Cogito ergo arbitro
I realize that. But NORMAL CONFIGURATION is defined (section 8.2):
NORMAL CONFIGURATION – The physical configuration and orientation of the ROBOT when the MATCH is started. This is the state of the ROBOT immediately before being enabled by the Field Management System, before the ROBOT takes any actions, deploys any mechanisms, or moves away from the starting location. This configuration is static, and does not change during a single MATCH (although it may change from MATCH to MATCH).
(emphasis mine)
Additionally, <R30-a> only allows the 2-second extension "Solely for the purposes of interacting with a BALL". At the beginning of the game, before powering up, you're not interacting with a ball.
(since 2004)
The Shooter (and Kicker) Saftey Thread Matt H. General Forum 5 20-01-2010 22:30
Team 399's Chassis and Kicker Tests Jeremy Germita Robot Showcase 10 18-01-2010 23:48
Robot Design: Frame Perimeter? IamMisplaced Technical Discussion 7 17-01-2010 15:03
Frame Perimeter x Bumpers sloteera Rules/Strategy 8 14-01-2010 11:18
Frame Perimeter? jimbot General Forum 2 10-01-2010 13:48
