Go to Post We don't tell new mentors about the Mentor VIP Adults Only Lounge, you'll get your key if we approve. We have leather couches, flat screens, and free corndogs in there. - Monochron [more]
Unread 23-01-2010, 15:22
DHSrobotics DHSrobotics is offline
FRC #1642
DHSrobotics is an unknown quantity at this point
Exclamation Watchdog Not Fed but, All Systems Are Go.
Even though the driver dashboard on the FRC Drivers Station reports that all of the basic functions are operational, we still get a "Watchdog Not Fed" error.
We would enjoy some help and input on this situation.
Unread 23-01-2010, 15:35
MikeNimmo's Avatar
MikeNimmo MikeNimmo is offline
Software
FRC #3126 (Flashpoint)
MikeNimmo is an unknown quantity at this point
Re: Watchdog Not Fed but, All Systems Are Go.
Try debugging. Make sure if the command to feed the watchdog is in a loop that something isn't ending the loop prematurely.
Unread 23-01-2010, 15:37
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
Try this:
http://www.chiefdelphi.com/forums/sh...ad.php?t=80885
"Great spirits have always encountered violent opposition from mediocre minds" - Albert Einstein
The FIRST Alliance
COMETS Robotics
Website
Unread 23-01-2010, 15:46
FRC #1642
Lightbulb Re: Watchdog Not Fed but, All Systems Are Go.
Our network is tethered, we have a direct connection to the Crio. The watchdog isnt not being fed at all.
Unread 24-01-2010, 22:01
cmh0114 cmh0114 is offline
AKA: Cam H
FRC #0217 (Thunderchickens)
cmh0114 will become famous soon enoughcmh0114 will become famous soon enough
Try extending the Watchdog starvation period. After you enable the Watchdog, set the starvation period to a few hundred milliseconds. The period used to be measured in seconds, now it's measured in milliseconds. You have to make sure to feed the Watchdog before it times out. I think the default time out period is 100 milliseconds, but don't quote me on that. So, if the code between getWatchdog().setEnable(); and getWatchdog().Feed(); takes longer than 100 ms to execute, it will time out, so you'll need to give it a longer period.
Watchdog not fed ahudson Programming 1 22-01-2010 11:26
Scoring Support Systems (Sounds like but is NOT an electronic jock strap) aaeamdar General Forum 0 16-06-2009 22:02
IR Board Not Working (But NOT Fried) itsme Electrical 2 18-02-2008 06:11
What are you all using to hold down your control systems? JackknifeJustin General Forum 10 02-02-2008 12:24
We dont know who all of you are, but thank you! archiver 2001 0 24-06-2002 02:29
