Even though the driver dashboard on the FRC Drivers Station reports that all of the basic functions are operational, we still get a "Watchdog Not Fed" error.
We would enjoy some help and input on this situation. |
Re: Watchdog Not Fed but, All Systems Are Go.
Try debugging. Make sure if the command to feed the watchdog is in a loop that something isn't ending the loop prematurely.
Our network is tethered, we have a direct connection to the Crio. The watchdog isnt not being fed at all.
Try extending the Watchdog starvation period. After you enable the Watchdog, set the starvation period to a few hundred milliseconds. The period used to be measured in seconds, now it's measured in milliseconds. You have to make sure to feed the Watchdog before it times out. I think the default time out period is 100 milliseconds, but don't quote me on that. So, if the code between getWatchdog().setEnable(); and getWatchdog().Feed(); takes longer than 100 ms to execute, it will time out, so you'll need to give it a longer period.
| Watchdog not fed | ahudson | Programming | 1 | 22-01-2010 11:26 |
| Scoring Support Systems (Sounds like but is NOT an electronic jock strap) | aaeamdar | General Forum | 0 | 16-06-2009 22:02 |
| IR Board Not Working (But NOT Fried) | itsme | Electrical | 2 | 18-02-2008 06:11 |
| What are you all using to hold down your control systems? | JackknifeJustin | General Forum | 10 | 02-02-2008 12:24 |
| We dont know who all of you are, but thank you! | archiver | 2001 | 0 | 24-06-2002 02:29 |
