Go to Post Looks like a perfect device for scaring the cats :D - Dan Petrovic [more]
Unread 23-01-2010, 14:56
Da Kid's Avatar
Da Kid Da Kid is offline
FRC #2957
Da Kid is an unknown quantity at this point
spinning kickers
We have a kicker that is just a piece of wood and can continuously spin. Can it countinuously spin? How long can it be out and what are the rules regarding this.
Unread 23-01-2010, 15:04
Scoutin' Master's Avatar
Scoutin' Master Scoutin' Master is offline
Read your Game Manual!
FTC #2753 (Team Overdrive)
Scoutin' Master is on a distinguished road
Re: spinning kickers
If I understand you correctly, that this arm swings parallel to the ground, you probably shouldn't have it continuously spin.
Rule G30 says this:
ROBOT Volume – During a MATCH, no part of the ROBOT shall extend outside the vertical projection of the FRAME PERIMETER, except as follows:
a. BALL Interaction Volume – Solely for the purposes of interacting with a BALL, MECHANISMS that are below the BUMPER may extend up to the BUMPER PERIMETER, for a period not exceeding two seconds. After returning inside the FRAMER PERIMETER, such MECHANISMS are not permitted to re-extend beyond the FRAME PERIMETER for at least two seconds.
Basically, you cannot have the arm extending out of your frame for more than 2 seconds at a time and cannot come back outside until another 2 seconds has passed.
What would be best is to control this arm, not have it continuously going out and in.
Hope this helps!
Team Overdrive FTC #2753
A big thank you to all of our sponsors and supporters!!
2006/2007: FVC #3179 - New Jersey Champions
2007/2008: FTC #74 - Ohio, Delaware, New Jersey, New York, and World Champions
2009: FRC #2753 - New Jersey Champions &
Archimedes Division Champions PARC champs, BRBR champs, & Brunswick Eruption champs
2010: FRC #2753 - NJ semifinalists, Philly semifinalists, ranked 44th in Archimedes division
2011: FTC #2753 - DE semi-finalists, NJ division finalists
Unread 23-01-2010, 15:11
BaByGrL's Avatar
BaByGrL BaByGrL is offline
AKA: Maria
FRC #0842 (Falcon Robotics team 842)
BaByGrL is an unknown quantity at this point
Send a message via Yahoo to BaByGrL
Are you guys using pistons to move the wood?
Unread 23-01-2010, 16:03
Da Kid's Avatar
FRC #2957
no, we're using a motor. i have another question can there be a break in the bumpers for the kicker to go through?
Unread 23-01-2010, 16:20
No. From what I understand, this year the bumpers must go all the way around the robot.
BUMPERS must provide complete protection of the entire FRAME PERIMETER of the ROBOT (i.e. BUMPERS must wrap entirely around the ROBOT).
Even if you could make a break in the bumpers, no mechanism can extend beyond the bumper perimeter.
Unread 23-01-2010, 16:23
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
No, no breaks in the bumpers, but the continouslly spinning kicker is 100% allowed. In fact, we are using one too.
Unread 23-01-2010, 16:38
President, VEX Robotics, Inc.
Be careful with this design. If the spinning kicker goes outside the frame perimeter at all, then it must retract within 2 seconds and must not go back out past the frame perimeter for 2 more seconds.
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 24-01-2010, 00:38
nitneylion452's Avatar
AKA: Joe Lee
Exactly what I was thinking. Remember that the ball cannot penetrate beyond 3" inside the frame perimeter, so you might have some difficulty with that. Also, a continuously spinning block of wood seems like it may burn out a motor, and have a lot of accuracy issues.
pic: 1270 SPINNING! FIXIT Extra Discussion 6 14-02-2008 07:45
Spinning Cylinders Rick TYler Technical Discussion 5 04-02-2006 02:36
Spinning a Piston Rod Mr. Ivey Pneumatics 4 08-11-2004 14:18
Gear spinning wrong way? Jnadke CD Forum Support 11 10-05-2003 10:23
