Go to Post The secret to this whole thing is that it's the robot that builds the team. - JohnBoucher [more]
Unread 23-01-2010, 15:38
Spar0117 Spar0117 is offline
FRC #1798
Spar0117 is an unknown quantity at this point
Extra CIM.... question
From reading the rules... i know that we are allowed an extra CIM(A total of 5 CIMs on a bot)
now the thing I'm having trouble finding in the rules is are we allowed and extra ToughBox trans.... so a total of 5 ToughBox trans on a bot
any info on this would be great
thx
Unread 23-01-2010, 15:42
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
Re: Extra CIM.... question
I don't believe that there are any restrictions on transmissions.
Go REX!!!
Unread 23-01-2010, 16:29
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
No limit on the number of toughboxes other than you cant have more than 120lb's worth.
Unread 23-01-2010, 17:56
fordchrist675's Avatar
fordchrist675 fordchrist675 is offline
"Wilfordito"
AKA: Wilford Jay Harris III
FRC #0675 (Technology High School Robotics)
fordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to allfordchrist675 is a name known to all
Send a message via AIM to fordchrist675 Send a message via MSN to fordchrist675 Send a message via Yahoo to fordchrist675
If the 5th wheel isnt for the drive train dont be so dead set on using a toughbox. Just a thought you could definitely find other means of successful transmissions.
It's not by how much you win, it's how you win. Respect your enemies, otherwise your no better than them which if you think about it that's true because we are striving for the same thing. To be FIRST
2010 SVR Creativity Award
2010 SVR Regional Finalists
2010 SAC Innovation in Control Award
Unread 23-01-2010, 18:17
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
You don't need the toughboxes for the drive motors either, you could make your own or use AM Shifter or AM super Shifters or a BB planetary or DeWalt something like that. That said, if you are a rookie team without many skilled machinists, the kit transmission would be the easiest way to go.
If you are set on using the Toughbox for the 5th CIM but are using it for non-drive, a Toughbox Nano would provide the same thing for smaller size and weight.
Toughboxes weigh alot. Weight = BAD. FRC robots are almost always right on the 120lb edge of things, and every ounce counts.
For high-speed rollers, direct-driving off a CIM or gearing it down with chain alone would probably work fine.
Kettering Motorsports
Unread 23-01-2010, 18:19
"Wilfordito"
Very true!
Unread 26-01-2010, 16:50
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
That all depends on how the robot is designed. Granted, most teams are at or over the weight limit at their first regional... but our team has consistently been under the past 3 years.
So much, in fact, that we've added 10-20 lb steel plates on all of our robots just to get up to the weight limit. Last year, we were smart about it, and integrated the steel plates into our design from the beginning
Unread 26-01-2010, 19:04
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
But Toughboxes can easily be lightened if you have access to a lathe. You can replace the extruded box with standoffs, and the internal gears can easily be swiss cheesed. Our favorite method of lightening the gears is to turn a .125 deep pocket into both sides on the lathe then drill six holes on the rotary table.
Of as we often do, take the gears and bearings from the Toughbox, maybe swap in different gear ratios to achieve the desired robot speed we're looking for, then design our own housing, whether CNC milled or CNC punched sheet metal.
Edit:
For high speed applications, our favorite method is to just use timing belt directly from the CIM motor drive shaft. This works good for 1:1 to 4:1 reductions. It's much quieter than roller chain at high speeds (what? it's faster than Aunt Jane at planting seeds?), and at these speeds the timing belt is pretty tolerant of loose belts.
Art Dutra IV
世上无难事,只怕有心人.
Unread 03-02-2010, 20:46
Please remember that there is a cost constraint that might come into play on your robot.
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
Extra Battery Question 1337pcgamer General Forum 1 16-02-2006 19:58
Another CIM Question Carlo Motors 4 14-02-2005 22:02
