Go to Post "So Ken Patton, Paul Copioli, and John V-Neun walk into a bar..." - JVN [more]
Unread 23-01-2010, 17:35
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: gyroscope problems
You should install it on every computer you could use to program. It takes a few hours, so installing it will take a long time.
The sensor should have a +5, GND, and signal/output pins. Take a PWM cable (3 pins), and cut off the end with the female connector that is long enough to connect from the gyro mounting point to the cRio analog board plus a little extra. Strip the three wires, connect the black to GND, red to +5, and white to SIG.
We generally put our gyros in a small project box and attach them to the robot with velcro.
As for software, the only thing you need to know is the volts per degree per second of the gyro, which can be calculated. I would guess that the sensor manual might tell you that, but I didn't read the sensor manual so I don't know for sure. If the gyro goes backwards, then make the gain negative.
Kettering Motorsports
AD22305 Gyroscope Data Sheet? Hadi379 General Forum 6 09-01-2009 11:41
No Gyroscope in KOP???? Sunshine General Forum 3 04-01-2009 15:50
Gyroscope Code Kevin Watson Programming 65 01-03-2008 23:46
Gyroscope saturation? Tom Line Programming 32 14-01-2008 12:07
Gyroscope Orentation Decay D.Viddy Programming 12 13-01-2003 14:43
