Go to Post Dear Mr. Lavery, Congratulations. For the fourth year running, you have successfully ruined my Christmas holiday with your untimely release of a most obfuscating, but no less tantalizing, hint. - dubious elise [more]
Unread 20-01-2010, 21:21
Team 2811's Avatar
Team 2811 Team 2811 is offline
WHAT DID YOU DO!? ..umm... whoops!
AKA: Ian Heffron
FRC #2811 (Stormbots)
Team Role: Electrical
Team 2811 is on a distinguished road
Exclamation Tunnel Blockers???
Hey to all of my fellow science nerds.
I was wondering if anyone was thinking about trying to block the tunnels. We are wondering about it because we have decided to go under the tunnel. If someone were to block the tunnel then our ability to move between the zones of the 2010 playing field would be gone. Tell us if we have to worry about this and even if the rules allow the blocking of the tunnel.
Thanks,
Ian Heffron
Team 2811 Rules Guru
Its about a day out!
Once, there were two marshmallows roasting over a campfire.
First marshmallow, "It is really hot up here."
Second marshmallow, "OH MY GOD ITS A TALKING MARSHMALLOW!!!"
The more you learn the more you know
The more you know the more you forget
The more you forget the less you know
So why learn?
Unread 20-01-2010, 21:24
dude__hi's Avatar
dude__hi dude__hi is offline
Now a CSWA
AKA: Cristian Arcega
FRC #0842 (Falcon Robotics)
dude__hi is an unknown quantity at this point
Re: Tunnel Blockers???
People blocking the tunnel is a definate worry for teams designing to use the tunnels to travel between zones and should be taken into account when designing your robot.
Powerpoint is a distraction, people use it when they don't know what to say...
2008 FIRST Chairman's Award Winner
The rules do not disallow blocking the tunnel. As a matter of fact, I would be surprised if most teams were not able to block the tunnel, and did not hesitate to do so against you, now that you have revealed a weakness of your robot.
GaryVoshol's Avatar
Cogito ergo arbitro
An opponent could block one end of the tunnel and not let you go through. But opponents can't block both ends and trap you there: http://forums.usfirst.org/showthread.php?t=13910
(since 2004)
Unread 20-01-2010, 21:27
[offtopic][humor attempt]But there wasn't a tunnel in the 2009 game, where that Q&A is posted. Therefore it doesn't count until it's crossposted or moved...[/humor attempt][/offtopic]
Unread 20-01-2010, 22:06
karatekid's Avatar
karatekid karatekid is offline
AKA: Cole
karatekid has a spectacular aura aboutkaratekid has a spectacular aura aboutkaratekid has a spectacular aura about
Lol. Nice spot.
YOU JUST LOST THE GAME!
Unread 23-01-2010, 13:19
ronald ronald is offline
FRC #1692
ronald is an unknown quantity at this point
Smile Re: Tunnel Blockers???
If one of the opponent's robot was blocking the tunnel, would our robot be able to push the other robot out of the way??
Unread 23-01-2010, 14:24
Brian Ha's Avatar
Brian Ha Brian Ha is offline
Teh Ha Kid
FRC #0302 (Team 302)
Team Role: Driver
Brian Ha has a spectacular aura aboutBrian Ha has a spectacular aura aboutBrian Ha has a spectacular aura about
Jux fyi ur screwed if you try to go under and get stuck. So if you plan on going under have a lot of strengh. Also just so you know most teams do not plan on going under the brigde so you might be ok.
Starcraft 2 Hit me up Cheese 972, or join the FRC chat room ingame
Unread 23-01-2010, 14:25
FRC #1692
Hey people, I found out the answer to my question and that one guy eric is right all you have to do is read the manual. The rules are in chapter 7.3.5.1, sections <G37> - <G39>.
Unread 23-01-2010, 14:26
FRC #1692
thnxs sure. well i already found out the answer so its all cool.
Unread 23-01-2010, 17:36
SAMBURGER's Avatar
SAMBURGER SAMBURGER is offline
AKA: Sam Johanson
FRC #2557 (SOTA Bots)
SAMBURGER is an unknown quantity at this point
Teams with robots that utilize Holonomic Drive or other small, fast designs will have a lot of trouble with other teams blocking tunnels. A possible solution to this is not using these said designs and sticking with the simple tank drive. and even if you decide to use these you should stay in your own zone rather then move around as a strategy. Keep it simple.
Tunnel part of Tower GaryVoshol Rules/Strategy 10 19-01-2010 13:20
Tunnel Height JamesByrne General Forum 3 11-01-2010 17:46
pic: Wind tunnel Pat Major Extra Discussion 20 19-02-2009 19:41
Wind Tunnel Wayne Doenges General Forum 48 21-01-2005 19:22
Bot Blockers Jeff Waegelin OCCRA 5 05-12-2001 23:14
