Go to Post But I suppose friendly reminders to read the manual are much better than sarcastic ones. - dtengineering [more]
Unread 23-01-2010, 14:23
Steve Warner Steve Warner is online now
Controls / Programming
FRC #0234 (Cyber Blue)
Steve Warner is an unknown quantity at this point
Camera using IterativeRobot class
Has anybody converted the 2010 Image Demo from the SimpleRobot class to the IterativeRobot class? How did you define the camera so it's not local to only the function it's defined in and therefore lost between iterations? The AxisCamera class seems to work differently from all the other WPILib classes.
Unread 23-01-2010, 17:49
Re: Camera using IterativeRobot class
I think I have an answer to my own question if anyone is interested. The line
AxisCamera &camera = AxisCamera::getInstance
can be put into a function and called repeatedly. The first time it's called it creates a pointer to the camera object and starts the camera app. After that it just returns the same pointer. Seems to works okay.
Unread 24-01-2010, 21:47
Mr. Lim Mr. Lim is online now
AKA: Mr. Lim
Declare a pointer in your IterativeRobot class:
AxisCamera * camera;
Then in your IterativeRobot constructor call:
camera = &(AxisCamera::GetInstance());
Use the dereference arrow -> instead of periods when calling camera methods.
Code above is from memory, so it may not work if you cut/paste, but hopefully it will help!
In life, what you give, you keep. What you fail to give, you lose forever...
Problem using the camera. Teh1337Bix Programming 14 21-01-2010 19:52
Is anyone using the Camera? GillSt.Bernards General Forum 19 05-03-2009 21:52
IterativeRobot Race Condition Dave Scheck C/C++ 1 14-02-2009 22:55
using servos with camera team877 Programming 2 01-02-2007 21:26
Using camera PWM out Cuog Programming 2 28-11-2005 14:17
