Go to Post "Mentors Only Work When Being Calibrated". - Calvin Hartley [more]
Unread 23-01-2010, 17:59
tutkows1's Avatar
tutkows1 tutkows1 is offline
FRC #2077
tutkows1 is an unknown quantity at this point
Question Camera IP Question
What IP address does the camera have to be to get it to work connected to the robot?
Unread 23-01-2010, 18:05
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Camera IP Question
192.168.0.90 I think
If that dosent work then its 192.168.1.90
Try running the Axis Camera Setup tool. That'll configure it too.
You also need to change the password of the Axis cam as described in the control system docs.
Kettering Motorsports
Unread 23-01-2010, 18:21
cappielloa cappielloa is offline
FRC #1099 (Discotechs)
Team Role: Electrical
cappielloa is an unknown quantity at this point
apalrd is correct. It is 192.168.0.90. Note that you do NOT need to set this IP as it is the default.
TheDominis TheDominis is offline
FRC #2152
TheDominis has a spectacular aura aboutTheDominis has a spectacular aura about
192.168.0.90 is correct.
You can use the camera and get video with these lines:
#include "AxisCamera2010.h" // make sure you add "-I(WIND_BASE)/target/h/WPIlib/Vision" to your include paths
// or include the folder in your #include
AxisCamera &camera = AxisCamera::getInstance();
camera.writeResolution(k160x120);
camera.writeBrightness(0);
If everything is installed correctly, this will work.
Unread 23-01-2010, 18:48
tutkows1's Avatar
FRC #2077
Thanks!
camera/code question coolperson987 General Forum 10 16-03-2009 20:59
camera question naor52 Programming 8 03-02-2006 00:07
Camera Purchasing Question Sgraff_SRHS06 Programming 3 29-01-2006 20:44
Camera Question fred Control System 3 13-02-2005 14:25
Camera Question fred Electrical 3 13-02-2005 14:25
