Go to Post Chain stretch debigulates drive train performance. - Richard Wallace [more]
Unread 23-01-2010, 09:31
Rafael2215 Rafael2215 is offline
FRC #2215
Rafael2215 is an unknown quantity at this point
Question The Bumps in this year's arean
Hi, I'm from team 2215.
First of all, I'm not sure I'm in the right forum, so if I'm not please direct me to the right one for my question.
We're currently building the Bumps and we have a problem. There were some updates and changes and we didn't have sufficient information, so we ended up having a bump that's 12 inches wide at the top, 13.25 inches high and 32 inches wide at the bottom, which means the incline is about 52 degrees, altough I think we got it wrong and it should be about 37 inches wide at the bottom and have a 45 degrees incline.
This happend because we thought the base of the bump is supposed be the exact same length of the tunnel. Or were we right?
Can someone please tell me what the real sizes are or at least were I can get them?
Thanks,
Team 2215
Unread 23-01-2010, 09:33
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: The Bumps in this year's arean
The Field Drawings are available here
http://usfirst.org/roboticsprograms/...nt.aspx?id=452
(section 6 Arena)
They are kind of complicated to figure out, but you NEED to be able to understand the field drawings to be able to know what the field will look like.
The dimensions in the rules text are not quite descriptive enough....
Unread 23-01-2010, 10:15
FRC #2215
(section 6 Arena)
Yeah, they aren't that descriptive, that's why I'm asking for someone to tell me the right dimensions. Are you saying that we're not allowed to get that informaion from other teams, and we need to figure it out ourselves?
Unread 23-01-2010, 10:21
MrForbes's Avatar
AKA: Jim
I'm saying that you should be able to click on the link, find the zip file with the arena drawings, and then look them over so you can see which one describes the bump, and use that drawing to make your own bump.
It's not that hard to do, and you'll get it right, and learn stuff in the process.
I would measure the one we made, but it's 15 miles away and locked in a secure compound right now.
Unread 23-01-2010, 10:45
FRC #2215
OK, thanks and good luck
Unread 23-01-2010, 10:52
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
FE-00033.pdf describes the entire field layout as well as supplies the parts list. Specifically, the Bump is described in GE-10047.pdf. All information necessary to dimension and build is found there.
Good luck and have fun!
Hi!
MrForbes's Avatar
AKA: Jim
If you can't find the drawing, or can't figure out what it means or what the materials are, please ask (and give us the drawing number that you are talking about)
I want to help, sometimes the best help is to show people how to do things themselves.
Unread 23-01-2010, 13:52
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
Originally Posted by rsegrest View Post
New dimension question...
G6.2.4 from udate number 3
"The PLATFORM is approximately 41 inches wide by 32 inches deep, and is at a height of approximately 21 inches above the floor. A 36-inch wide by 18-inch tall TUNNEL under the PLATFORM, providing a passageway between the MIDFIELD and the adjacent end ZONES."
Rev B Game Field Specs:
Inside wall = 16 1/2 x 32 1/2
Upright stiffener = 17 x 3 1/2
SO we have built a platform to specs and prototyping team is complaining that platform is 1 inch too short...which is correct, the manual or the specs?
Sorry for reposting but I posted this in another (read incorrect) thread...
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Unread 23-01-2010, 18:02
FRC #2215
I appreciate your good will, but perhaps I have'nt made myself clear enough.
I have the manual, I have all the drawings, all I ask is for someone to tell me whether I got it right or not, so we don't waste our time again building another incorrect bump.
So, again, I'm refering to the trapezoid profile of the bump: the top base is 12 inches long, the height is 13.25 inches, and the lower base is 38.5 (=13.25*2+12) inches long (while the side of the tunnel which is in contact with the bump is 32 inches long, which means the bumps extend longer over the length of the FIELD than the tunnel does), making the angle of the sides 45 degrees.
Am I right?
Unread 23-01-2010, 18:49
baruffir baruffir is offline
Me
FRC #0178 (Enforcers)
baruffir is an unknown quantity at this point
My team had the same debate. The field drawings show a 45 degree cut at the bottom of the ramp, so that's how we made ours.
Unread 23-01-2010, 18:50
GaryVoshol's Avatar
Cogito ergo arbitro
GE-10047 shows that the length of the support rib, which is inside the bump, is 32.5 inches. But the rib doesn't make the complete triangle, so by adding the distance for the full triangle the interior of the bump is a little over 38.5 inches. Add the plywood shell, and you're around 40.25 inches, plus you still have to add the carpet.
(since 2004)
Unread 23-01-2010, 20:12
MrForbes's Avatar
AKA: Jim
Am I right?
Here are the two pages of the drawing of the bump, and a drawing my son did showing the bump and tunnel and tower as best we could figure them out, using the field drawings for reference. Does this answer your question?
ID:	8369  Click image for larger version
ID:	8370  Click image for larger version
Unread 24-01-2010, 00:54
FRC #2215
Yes, it does answer my question.
Thank you all very much,
good luck
Unread 24-01-2010, 05:48
techedguy's Avatar
techedguy techedguy is offline
Technology Education, PFHS
AKA: Sal
FRC #4520 (Roboteknix)
techedguy is just really nicetechedguy is just really nicetechedguy is just really nicetechedguy is just really nicetechedguy is just really nice
Just coming from building all of ours, I found the quickest solution for me was to rip the plywood to 32-1/2" then cross cut that into 12-7/16" strips. I then made a quick cross cut jig on the table saw with a stop in place to set those pieces in at 45 degrees and contact the blade right at 10-1/4". This yielded 9 ribs per sheet...72 diagonal cuts later they are all 36 ribs.
If anyone did all this with a SkilSaw you have my utmost respect and a steadier hand than I do.
The tops and sides are pretty simple as well. If you are only building one bump section ignore me completely...we joined up with other local teams to build a field at a sponsor's place of business (an amazing opportunity for kids, mentors, parents and sponsors from multiple teams to come together and sweat a bit).
Salvatore Lorenzen, M.Ed, Ed.S.
Mentor/Coach/Teacher
I am not who I hope to be, but I am trying. I am giving it my all to improve me; and I’m thankful at the end of each day that I’m not the guy I used to be.
FRC #4520 - Misfit Toys
2012 Spokane Regional WFA
2009 Idaho GIANTS Award
Variations of the Bumps? Creator Mat General Forum 4 14-01-2010 21:33
are this year's fisher price motors as good as the old ones with the black case? waialua359 Motors 2 11-01-2007 22:51
Can we use the 2005 RC for this year's robot? DemonYawgmoth Control System 6 13-02-2006 17:34
What Was the Source of This Year's Game? Wayne C. General Forum 1 23-04-2004 22:49
The key to this year's game (long) archiver 2001 6 23-06-2002 23:05
