Go to Post High heels on a Segway takes quite a bit of adjustment - as I learned the hard way. - Jessica Boucher [more]
Unread 23-01-2010, 18:25
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Festo Connectors
Hello,
Here:
http://www.festo.com/rep/en-us_us/as...structions.pdf
Electrical Connection
Connect the e-box’s (seperate component VAVE-..) to each end of the valve as shown in the picture below. After this connection is secured connect the supplied cables to the connectors. Attached one end of each cable to a +24VDC signal and the other to a 0VDC signal.
When the valve is switched on the LED will turn on.
Is the connector for the festo supplied? I can't seem to find it if it is. What is the recommended way for wiring it using KOP parts?
Jacob
Unread 23-01-2010, 18:32
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
Re: Festo Connectors
If you all are around tomorrow i can talk to our electrical engineer and have him give u a call or if you are available swing by for help.... As I would not follow any of my wiring advice
They do have a connector for wiring them it is nice actually screws into the body so it cant be dislodged....
if u look here the pic here has the connector in it http://www2.usfirst.org/2007comp/oth...s%20Manual.pdf
Unread 23-01-2010, 18:35
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
A quick check of the KOP dosent have that valve you linked to. A re-check says the same thing. The only valve I can find in the KOP is a 24v double valve with built-in leads. If you really want to us the valve, you could try to solder wires to the terminals.
Kettering Motorsports
Unread 23-01-2010, 22:38
Yes, the connectors for the 24v Festo came in the KOP. The valve came as a kit in it's own bag with the ports and wires.
It all looks like this.
Unread 23-01-2010, 23:36
AKA: Jacob Komar
Hey all,
Sorry, I found the cables about three minutes after I posted. My mistake
Jacob
Unread 02-02-2010, 18:36
Generator of Entropy
FRC #2973 (The Mad Rockers)
We just got our festo KOP valve - it came late as a replacement part - and we seem to be missing the VAVE connectors that snap on to the sides of the valve. We got the connectors with the wires but there is no way to connect them to the valve.
Should I be looking somewhere else in the kit for those connectors, or should they come in the festo valve bag (marked vuvg-asy)?
Unread 02-02-2010, 19:00
They should have been in the Festo valve bag. It was a(n) (in)complete kit.
Unread 02-02-2010, 22:36
Thanks Mark - I guess I'll have to file another replacement part request
Unread 06-02-2010, 17:01
kws4000's Avatar
kws4000 kws4000 is offline
Team Mentor - Programming
AKA: Krazy Karl
FRC #2405 (Divided by Zero)
kws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the rough
Question Re: Festo Connectors
I have the Festo solenoid built using KoP, but how do I wire it to the breakout? I think both leads have to be twisted into a single connector, but I might be wrong.
Thanks
Unread 06-02-2010, 19:26
The leads don't twist together.
You use code to turn one side off as it's opposite is turned on and vice versa.
The two wires (1-red & 1-black) from one side of the Festo go to a 2-pin connector and plug into the Solenoid Breakout, on say position 1. The Solenoid Breakout pins are marked as to (+) & (-), the black wire goes on the (-) pin.
The two wires (1-red & 1-black) from the opposite side of the Festo go to a 2-pin connector and plug into the Solenoid Breakout, on say position 2.
I'll try to rig up a photo later.
Unread 06-02-2010, 21:56
Here is a photo for visual learners.
Does this help?
Unread 07-02-2010, 17:34
kws4000's Avatar
AKA: Krazy Karl
Talking Re: Festo Connectors
Thank you a whole bunch!!!!
I'm fairly sure I can get us going now.
Thanks again!
Unread 10-02-2010, 13:59
TeraViks's Avatar
TeraViks TeraViks is offline
AKA: Brian Induni
FRC #3145 (TeraViks)
TeraViks is a jewel in the roughTeraViks is a jewel in the roughTeraViks is a jewel in the roughTeraViks is a jewel in the rough
I may be a bit slower than the rest - isn't the new Festo valve 24v and the breakout 12v??? Or does the double connection to the valve give it the 24v it needs?
Thanks!
Unread 10-02-2010, 14:03
To use a 24v solenoid you must supply 24v to each side.
This can only be done by wiring one Solenoid Breakout from the two empty 24v contacts on the Power Distribution Panel shared with the cRIO.
For details, see page 2 & 3 of the 2010_Robot_Power_Distribution_RevA.pdf
Unread 10-02-2010, 14:05
Jones571's Avatar
AKA: Corey
FRC #0571 (Paragon)
Thanks!
This website should help you with your issue:
http://www.team358.org/files/pneumatic/
Festo Solenoid lostkhaos Pneumatics 5 21-01-2010 10:15
Festo itay_ms Electrical 3 30-01-2007 09:08
Slip connectors (custom electrical connectors) Damian Manda Electrical 2 08-02-2003 17:53
Festo Valve Gary Bonner Pneumatics 2 26-02-2002 17:48
RJ-45 connectors, DB25 connectors and the like: legal or no? Andrew Wyatt Technical Discussion 6 04-01-2002 22:53
