Re: Still no camera feed
Thanks. I'm pretty optimistic that reimaging will work. I'll let you know presumably on Monday how everything turns out.
Did your DS report v19 before you fixed it? |
We're having the same problem over here.
I'll let you guys know if we make any progress. |
I was saying on another thread that I had to go to C:\Program Files and manually delete the folder with the driver station software, then reinstall the software, before the feed worked. Just uninstalling and reinstalling the update didn't work.
OK, our feed is working. I'm not really sure what did it but here's what we did:
1. deleted our current project and made a new 2010 Image Demo project 2. added an FRC account to the camera 3. ran the camera setup utility 4. reformatted the cRIO After that, it was all good. If anyone has any ideas why this worked, I'd be glad to hear it. |
If you never had an FRC/FRC account on the camera before, then the cRIO would have been refused login rights...
Our team has had the same problem as you. However, we recently fixed this and I posted detailed step-by-step instructions in this thread: http://www.chiefdelphi.com/forums/sh...ight=windriver
Hope this helps! - Mike and Team 2200 |
#7
Finally got the cRIO to reimage without any errors...AND absolutely no change. I'm not worried about the DS update because I've been using another laptop that obviously never had the old version on it. I'll still pull out our second cRIO, maybe tomorrow and try it. I'm happy that some people are having better luck than I am...
#8
Have you tried installing the LabView update on the ClassMate PC? If you have tried everything else, this could be your problem. Most people develop on another PC and install this update on that machine, but not the ClassMate itself - because it doesn't really make sense to do the update on a machine you won't be developing with. Anyway, this was one of the last steps we did on our way to getting an image. Try that if you haven't already. Also, are the Ethernet lights on port 2 on? Make sure you have a crossover Ethernet cable as well. - Bryce |
#9
ping "192.168.0.90",4 ? |
#10
I was a little too quick with my last post. Turns out that the reimage worked, I had just tried so many things with the code that I needed to fix a few things there. I was never able get the console shell to launch in order to try pinging it.
One problem down, many more to be discovered. Thanks for all of the help everyone. |
| Yet Another Axis Camera Live Feed Issue | z2daj | FRC Control System | 2 | 24-01-2010 13:47 |
| Any way to speed up the camera feed fps? | Sean Raia | Programming | 10 | 22-01-2010 22:31 |
| Live Feed with Axis Camera | CHSboy | Programming | 6 | 24-03-2009 14:43 |
| Drivers' Station Camera Feed | dhawk085 | Technical Discussion | 4 | 25-01-2009 19:12 |
| 2009 - Live camera feed to drivers during a match? | Travis Hoffman | Rules/Strategy | 23 | 21-01-2009 17:43 |
