Go to Post If there isn't unity in your team, the outcome will never be good. - Arefin Bari [more]
Unread 23-01-2010, 16:32
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
Wiring Digital Sidecar
Ok, so here's the question...last year we were allowed to use 20AWG or larger to wire the digital sidecar and we used 10AWG. This year the manual (Control Manual 3.4.1.2) lists this
"Nominal 12V power input via WAGO 734-132. WAGO 734-102 is the typical mating connector with wire size between 14 and 20 AWG."
Why and does this make a difference in the operation of the digital sidecar?
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
Unread 23-01-2010, 17:10
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Wiring Digital Sidecar
10AWG is way way way way way too big. 18AWG is what we use and it works fine for that amperage. 10AWG is for 40+ amps, and should only be used for CIM motors, and possibly F-P motors if they are under heavy load. 16 AWG is adequate for 30 amp circuits, although we usually use 12AWG for all of the feeds to the Jaguars/Victors from the PD board, then 16AWG from the Jaguar/Victor to the motor. We use 16AWG for all the motor and compressor spikes, 18AWG for the pneumatics spikes, DSC, Analog, cRio, and Solenoid boards. Use 18AWG, if you don't have any then use something bigger. Do not use 10AWG ever except for your main drive motors, use 12AWG for the other 40 amp loads. It does not really make a difference, especially if you dont use alot of servos. The DSC is only really capable of drawing a few amps, so using 10AWG wire (40+ amps for our use) will not increase capacity of the outputs.
Kettering Motorsports
Unread 23-01-2010, 17:56
Phoenix Spud's Avatar
Phoenix Spud Phoenix Spud is offline
Everyone. Everywhere.
FRC #3132 (Thunder Down Under)
Phoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond reputePhoenix Spud has a reputation beyond repute
One of the reasons that you would not want to use thicker wire is weight, it is always an issue for teams, and copper weighs a LOT!
Sarah Heimlich
Outreach Mentor | Business Mentor
FIRST® TEAM 3132
Unread 23-01-2010, 17:58
rsegrest's Avatar
Only reason we used that size was because we were told that because of the 20amp breaker we would not push more than the sidecar could handle. Thanks for the advice and info!
~ Unknown
Unread 23-01-2010, 18:53
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
We used 20AWG wire for everything on the cRio and it worked fine.
Unread 24-01-2010, 00:38
You need to remember that circuit breakers are there to protect the wiring from burning up when something else goes wrong and tries to pull too much current. They usually have nothing to do with how much current a device normally pulls. The FRC game rules make it clear that the circuit breaker rating has everything to do with the size of the wire used.
Unread 24-01-2010, 08:35
I am guessing that last part is a typo, #10 won't fit the connector. In reality the side car draws so little current that a #18 is almost too big but it fits the breaker sizing for a 20 amp breaker.
Unread 25-01-2010, 11:25
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Please check the rules on those wire sizes. Per <R47>:
40 Amps needs 12AWG or larger (the 10 you listed is adequate)
30 Amps needs 14 AWG or larger (the 16 you listed is NOT adequate)
20 Amps needs 18 AWG or larger
From your listing, there are several illegal items: 16 gauge wire if you're using 30A breakers, and using 16 gauge from the Jags/victors to the motors, assuming those are on 40A circuits (as they really should be) - those MUST use 12 gauge or larger.
Digital Sidecar problem Jon Stratis Electrical 4 27-02-2009 09:12
Digital sidecar cable Noamr Inventor 1 22-02-2009 15:56
No RSL on Digital Sidecar shobuda999 FRC Control System 16 08-02-2009 14:28
Digital Sidecar Problems cabbagekid2 FRC Control System 13 31-01-2009 17:23
Digital Sidecar Resistor NinJA999 Electrical 5 30-01-2009 19:53
