Go to Post Many people read ChiefDelphi, not just members of FRC teams. - JaneYoung [more]
Unread 23-01-2010, 19:15
bobwrit's Avatar
bobwrit bobwrit is offline
//No Comment
AKA: ...
FRC #1977 (Loveland High Robotics)
bobwrit is just really nicebobwrit is just really nicebobwrit is just really nicebobwrit is just really nicebobwrit is just really nice
Help triggering Pneumatic
So we have a SMC SY3000 series solenoid wired to ports 1 and 2 on the cRio. There is only one red light lit at a time, and when we press the trigger, it changes to the other one. The problem is that the pneumatic that we have attached to it doesn't fire. We have checked pushing the orange buttons on the solenoid, and that works just fine. What are we doing wrong?
FRC Team 1977 Alumni
Has Attended:2008 Colorado regional
2009 Colorado Kickoff
2009 Colorado Regional
2010 Colorado Kickoff
2010 Colorado Regional
The most exciting phrase to hear in science, the one that heralds new discoveries, is not "Eureka!"(I found it!), but rather, "Hmm.... That's funny" ---Isaac Asimov
Chance favors the prepared mind ---Louis Pasteur
And you can tell me, that I can't make a diffrence because I'm just one, but one is all it takes to start it. And you can tell me, that I can't change the world because I'm too young, but I wont stand here and be your target. ---FM Static
Unread 23-01-2010, 19:18
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
Re: Help triggering Pneumatic
I'd check this out and double check your set up: http://www.team358.org/files/pneumatic/ great resource by Mark and team 358
Unread 23-01-2010, 22:43
Are you using a 24v or 12v solenoid and where is the Solenoid Bumper getting it's power from (12v or 24v)?
Unread 23-01-2010, 23:15
bobwrit's Avatar
//No Comment
AKA: ...
12v Solenoid, 12v Bumper.
Unread 23-01-2010, 23:20
How about the tube plumbing?
Are the ports labeled?
Try connecting only the pressurized input line and identify the port it's connected to.
Unread 23-01-2010, 23:22
ATannahill ATannahill is offline
AKA: Alex Tannahill
Is the valve closed?
Are there any leaks?
Is there enough pressure in the tubes to push the piston?
- Arizona North
Unread 23-01-2010, 23:53
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Are you make sure to flip both valves? You need to open one valve and then after a slight delay close the other, in order to change the position of your cylinder.
pneumatic cylinder help. Brandon_L Pneumatics 2 26-01-2008 10:55
HELP! We need pneumatic wiring help! BrittanyV Pneumatics 13 10-03-2006 09:26
Encoders, interrupts, and edge-triggering issues Alan Anderson Programming 6 11-03-2005 16:06
basic pneumatic help needed Anton Programming 4 10-02-2005 16:02
Pneumatic help archiver 2001 4 23-06-2002 22:53
