Go to Post There's a fine line between cockiness and confidence. Confidence is one of the major keys to success and happiness in life. As long as one can carefully stay on the right side of the line, staying connfident while remaining humble, and ego can be quite beneficial. - Karthik [more]
Unread 23-01-2010, 19:42
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Black jaguars: not working
What about the other list of suggestions in my last post? Also... if you have LabVIEW installed, you could run the voltage mode example to see what enumerates on your robot.
-Joe
Unread 23-01-2010, 19:47
ellisk ellisk is offline
FRC #1540
ellisk is on a distinguished road
Yes, we've tried the other suggestions. The cable is fine, it's plugged in on the left, there is a 100 ohm resistor on the left jack, and I can see the driver loading on the console when the cRIO boots.
EDIT:
Here's the startup message from the cRIO's console:
FPGA Hardware GUID: 0xAD(a bunch of hex digits)
FPGA Software GUID: 0xAD(a bunch of hex digits)
FPGA Hardware Version: 2010
FPGA Software Version: 2010
FPGA Hardware Revision: 1.3.0
FPGA Software Revision: 1.3.0
* Loading StartupDlls: FRC_BlockJagBridgePlugin
FRC_BlockJagBridgePlugin was compiled from SVN revision 10
task 0x12d9610 (t2) deleted: erno=0 (0) status=0 (0)
* Loading StartupDls: FRC_UserProgram
...FRC_UserProgram failed to load.
NI-VISA Server 4.5 started successfully.
task 0xe414e8 (t1) deleted: errno=1835009 (0x1c001) status=1 (0x1)
Welcome to LabVIEW Real-Time 8.6.1f2
(the last line is odd, considering that it's not in LabVIEW mode...)
When I run the aforementioned program, I get the following error at startup, presumably from the call to Init of the CANJaguar in the constructor of the program:
>>>>ERROR: status == -63194 (0xFFFF0926) in InitJaguar() in C:/windriver/workspace/Spy/CANJaguar.cpp at line 32
Unread 23-01-2010, 19:53
If you just unplug the serial connector from the cRIO and plug it into a PC, does bdc-comm see the Jaguars?
Unread 23-01-2010, 23:15
ChristopherBuck's Avatar
ChristopherBuck ChristopherBuck is offline
FRC #0612
ChristopherBuck is a jewel in the roughChristopherBuck is a jewel in the roughChristopherBuck is a jewel in the rough
Hi, we had a seemingly similar problem with our CAN bus setup (using LabView). the driverstation would display an error regarding "CAN-Recieve.vi" and "operation not completed in time" (or something like that), so a timeout error of sorts. essentially, the cRIO was not getting a confirmation of initial setup from the black jag, or other jaguar- I forget exactly which. Anyway, we went into the code for initializing a 4motor robot drive system. and modified it such that it bypassed this error point (removing CAN-Recieve.vi). Then it worked perfectly. So my guess is that you may be able to do something similar in C++.
Unread 23-01-2010, 23:33
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Answering for ellisk and in answer jhersh's question... yes the same cable works fine off a PC to talk to the Jaguar via the command line and GUI interface. The firmware was updated and ID set. No other changes were made to the Jaguar's settings. Also, for what it's worth, different cRIOs exhibit the same problem.
Once thing we didn't do was wire any of the the RS-232 handshake lines in the connector, things like CTS, RTS, DTR, DSR. The manual didn't say anything about that so we're assuming the cRIO doesn't care. Is that true?
Unread 24-01-2010, 00:12
The Jaguar only has connections for RX and TX.
Unread 24-01-2010, 00:31
That a great point... I forgot to ask if the robot was enabled when you got this error. The current image (v19) will not cause a reply if the robot is disabled. This means that, for the moment, you can't call any "Set" commands while the robot is disabled without an error. This will be addressed in the next update. It won't cause any trouble (the way the C++ library is written), but it will create some errors on the DS. As ChristopherBuck noted, in LabVIEW it is written with status chaining so one of these errors will prevent it from working from then on.
Unread 24-01-2010, 01:52
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
We do have the 100 ohm terminator in place. We know the Jaguars only have TX and RX but I wasn't clear whether the cRIO needed to have the other handshake lines jumpered at it's end. ellisk will have to answer about the robot being enabled.
They were trying a 2CAN ethernet adapter when I left the lab tonight to see if that yields better results. We'd still like to get the "official" RS-232 solution working though.
Unread 24-01-2010, 02:31
The cRIO does support hardware flow control, but it's disabled by default and the BlakJagBridgePlugin does not enable it.
-Joe
Unread 25-01-2010, 13:05
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
I have been having an issue with intermittent signals getting to the Jags. We currently have updated the firmware on both Jags connected (One black and one gray each with its respective firmware update) through the RS232 port on the cRio. There is a 100 ohm termination resistor inside the DB9 shield between CANL and CANH (the green and red wires). There is a 6 pin cable running from the RS232 to CAN inverter to the LEFT port of the black Jag. I have then tried both a 4pin and 6pin cable from the RIGHT port of the black Jag to the LEFT port of the gray Jag (just to see if I had made a bad cable). I then created a short Termination cable that only has a 100ohm resistor between the green and red wires. This short cable is plugged into the RIGHT port of the Gray Jag. I have tried communications with and without this termination cable and get similar results.
If I just send the Jags a constant max output value, they will run and then sputter, and then run, yada yada yada. It sounds as if I have a physical layer problem - i.e., signals not propagating properly.
Also, I have obviously been able to connect with BD-COM to assign IDs and re-flash the firmware...
So my questions are:
Should the termination resistor be on the cable at the LEFT port of the Gray Jag, or is it correct the way I have it?
Has anyone else been able to get a connection, but suffers from intermittent signal loss?
- Bryce
P.S. I have attached some pictures of errors that I am receiving in the NetConsole.
P.S.S. This is somewhat of a bummer, because I have written code to make use of the Speed and Position modes, but can't test it until I at least have a reliable communication interface...
Name:	CAN Problem - Black Jag.JPG
ID:	8381  Click image for larger version
Name:	CAN Problem.JPG
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
Unread 25-01-2010, 13:33
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
It may not be your problem, but we ordered a RJ11 cable tester to test our CAN cables. We have 9 Jaguars on our board and can't have one of those cables being marginal if we can help it! You can get one for anywhere between $7 and $100+.
We still don't have our first Jaguar working on CAN so we'll see if we get to use that spiffy tester. For what it's worth we're getting this one because of it's good reviews and middle range price.
Last edited by Dale : 25-01-2010 at 13:57. Reason: Removed for incorrect info on single terminators
Unread 25-01-2010, 13:46
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
There should be just one terminator...at the end of the chain. Have a terminator inside the shell of the DB9 defeats the purpose of reducing reflections. See this article.
Two 120 ohm resistors are required on a CAN bus. One at each end of the BUS. The 2CAN contains one of the resistors internally that can be removed via a jumper. The second jumper needs to be placed by the user. My suggestion is to use the second RJ-11/12 connector on the Jag for this. I do not know if the Jaguar has an internal 120 ohm resistor or not. Maybe Scott Emley can answer this. If it does not, you will need to place one at the beginning of the BUS as well.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 25-01-2010, 13:56
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
I stand corrected on the terminator! In re-reading page 29 of the Jaguar BDC24 getting started guide it clearly says you need a 100 ohm resistor at both ends. I wonder if that's our problem with getting the Jaguars to work via CAN! It would seem unlikely given that we only have one Jaguar in our test setup but it's certainly worth a try.
Unread 25-01-2010, 14:05
Bryscus's Avatar
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Dale,
The instructions in the Getting Started Guide show a 100 ohm connected between red and green (CAN_L and CAN_H) inside the RS-232 to CAN converter. If you did this, you should have the proper termination.
- Bryce
P.S. I wonder if the termination needs to occur closer the the black jag than at the converter. Our cable is only 5 inches or so, but maybe even that is too long?
Unread 25-01-2010, 14:11
Dale's Avatar
Head Coach & Mentor
AKA: Dale Yocum
We had a 100 ohm terminator in the empty RJ11 plug on the Jaguar but didn't have one in the left one where the serial data was coming in.
Serial to CAN Gateway in new Black Jaguars? dmcguire3006 Electrical 54 26-01-2010 07:32
Jaguars arent working yoavh360 Electrical 6 19-01-2010 17:20
Victors and Jaguars not Receiving Signal? excel2474 Electrical 1 12-02-2009 16:41
jaguars suddenly not working Mr. E Technical Discussion 1 07-02-2009 21:09
Jaguars working with 2.4 Ghz R/C NOV8R Technical Discussion 0 09-01-2009 16:15
