Go to Post You lame pig farmer! I'm not talking about a bunch of dudes sitting around eating their packed lunches that Mommy made. - Paul Copioli [more]
Unread 17-01-2010, 16:44
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
2010 346 Programming team problem log
This is a log of our problems we have encountered in the 2010 build season. The topics will remain open until a solution is found. At that time I will update the post with the solution. The hope is that if anyone has the same problem thay can use this as a refrance for their own problems or if someone has had one of our problems and they have a solution they can post it.
A) Problem: Dashboard will not show after update
Status: Closed
Solution: 1) Open C:\Documents and Settings\All Users\Shared Documents\FRC DS Data Storage.ini
2) Locate DashboardcmdLine=
3 change to DashboardcmdLine="c:\\program files\\frc dashboard\\dashboard.exe"
B) Problem: cRio will not update to v19 properly
Status: Open
Steps done so far: 1) Updated DS
2) Did Manditory Labview Update
3) used crossover cable (pink) opened image tool
4) selected Java. checked format. clicked apply
5) image tool indicated cRIO was in safe mode
6) shut down cRIO toggled safe mode switch and tried again
7) image tool indicated cRIO was in safe mode
8) repeated 6 and 7 several times
9) got frusterated
10) put cRIO in safe mode and allowed image tool to format
11) took cRIO out of safe mode and clicked java but NOT format
12) image tool said cRIO updated
13) cRIO's status light blinks 3 times pauses and repeats
todo: take a break. register labview and try updating again
C)Problem: Netbeans not uploading code to cRIO
Note: may be related to (B) or (B) may be related to (C)
Status: Open
Steps: 1) created new project in netbeans with the simple robot template
2) clicked build main project (basicly a blank program for the robot)
3) netbeans build error no rout to host 10.0.0.2
4) made sure DS set to team
5) netbeans came up with same error
EDIT (1/18/10 7:19est)
D) Problem: Driver station sometimes shows black screen when logging off from driver account
Status: Open
Steps: 1) research - probably a common windows problem
2) Possible solution http://support.microsoft.com/?kbid=328934
More to come and solutions hopefully sooner then later
Unread 17-01-2010, 17:33
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: 2010 346 Programming team problem log
Don't use crossover cable
Watchdog.Kill();
Unread 17-01-2010, 17:34
Lucretius Lucretius is offline
#395 Mentor, #1884 Alumnus
FRC #0395 (2 Train Robotics)
Lucretius is an unknown quantity at this point
The 10.0.0.2 error occurs when you haven't set your team number in the FRC Plugin options in NetBeans.
Unread 17-01-2010, 17:35
byteit101's Avatar
also, when imaging, did you set your Team #?
Watchdog.Kill();
Unread 17-01-2010, 17:38
The one time I had to put it in safe mode to format, I also had to format the second time. Hopefully that works for you.
Status: Open
Make sure to set your team number in the the netbeans options. You won't be able to successfully upload code until the cRIO is imaged.
Unread 17-01-2010, 19:15
AKA: Bryant
We will try. it connects fine but the instructions say to use xover
Thanks I will look into that
Yes and device name to team346
when i went to image the second time the cRIO did show up with the ip as 10.3.46.2
Unread 22-01-2010, 22:02
AKA: Bryant
So we still have no success with re-imaging. Followed the steps on http://delta.ni.com/content/message/3242.
Status light starts off with 3 flashes
1. Do an IP Reset
set the IP Reset DIP switch on the cRIO to ON
push reset button on cRIO
Set the IP Reset DIP switch on the cRIO to OFF
At this point the cRIO's status light flashes once
2. Power off the cRIO, then Power it back on
2a. Turn off your computer's firewall
3. Connect to computer to the cRIO using the crossover cable
IP Address on computer 10.0.0.6 SubNet 255.0.0.0
4. Run MAX (Measurement and Automation) to reset IP address (it is now 0.0.0.0) on the cRIO
Tools\NI-Serial\Ethernet Device Configuration
This should find the cRIO and show the MAC address
5. Click Properties and set the IP Address to 10.0.0.2 SubNet 255.0.0.0
6. In MAX, click Remote Systems and then F5 to refresh and you should now see the cRIO.
7. Expand the cRIO under Remote Systems,click on Software, and click on Add/Remove software
Reload the NI-RIO 2.4.1 software
The software was NI-RIO 3. something. Figured it was part of upddate and reloaded anyway.
Afterwords we are back to one flash
1. Flip the cRIO Safe Mod DIP switch into the ON position.
2. Reset the cRIO so that it boots into safe mode.
3. Disable safe mode by flipping the DIP switch to OFF.
4. Using the FRC cRIO Imaging Tool, format the controller by checking the "Format Controller" checkbox. See the tutorial Using the FRC cRIO Imaging Tool for more information.
At this point in the imaging process we checked the format checkbox and filled in the rest of the information selecting the LABVIEW language.
The program starts by extracting the image then says connecting at which point the lan connection in the tray says cable disconnected. once it reconnects the image program says the cRIO is in safe mode. Power down switch to safe mode run the program again. we proceed with the format this time but even after 20 minutes it still says its formatting. Reset in safe mode off still having 3 flashes and go back to the image tool. try to image and it says its in safe mode.
HALP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!
5. The FRC cRIO should automatically reboot and then you will be off and running again.
Unread 22-01-2010, 22:09
Tom Line's Avatar
Tom Line Tom Line is online now
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
We ran into this exact same issue when formatting ours earlier this week. The formatting tool does NOT error out when it cannot connect! I discovered that our firewall was blocking it. The program sat and said "formatting" for more than 30 minutes. When the students told me what was going on, I went over, took the Crio out of safe mode, turned off the programming computer's firewall, and imaged the Crio with no problem.
Do you have ALL firewalls turned off on the programming computer?
Unread 22-01-2010, 22:15
AKA: Bryant
I will check it again if all else fails we will also try the solution posted on http://decibel.ni.com/content/message/3360
Windows firewall is Off
in advanced it was checked for LAN now its unchecked
in advanced settings all services were unchecked now they are checked
same with ICMP
AVG webshield disabled
Internet properties local internet security set to low
Anything i missed???
Unread 22-01-2010, 23:55
Tom Line's Avatar
Did I read it incorrectly, or have you not tried turning off safe mode and imaging?
Unread 23-01-2010, 07:59
AKA: Bryant
i may not have been as clear as i thought.
first attempt safe mode was OFF.
---error popped up saying it was in safe mode
second attempt safe mode was ON
third attempt safe mode was OFF
---still same error
fourth attempt safe mode was ON
---allowed it to format which never completed
Unread 23-01-2010, 19:17
Your detailed description of what you did made it sound like you just turned off the "safe mode" switch without rebooting. It's hard to be sure what really happened from what you said.
Unread 23-01-2010, 20:20
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Are you imaging using your own laptop, or by using the supplied Classmate PC?
We were unsuccessful getting it to reimage using my personal laptop - even with all AV and firewalls turned off. But on the first try using the Classmate via the supplied pink crossover cable, it worked fine.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 24-01-2010, 00:20
AKA: Bryant
we got it. apparently the safe mode switch was off its rocker (literally). we pushed down really hard while switching it and click its not in safe mode anymore. Imaged fine after a format through MAX. Now to get it to run linux jk jk... maybe later
Tips for C++ programming the 2010 control system woodk C/C++ 12 23-01-2010 21:38
Thank You Teams 346 and 88 JAZAD1 Thanks and/or Congrats 4 23-03-2009 19:14
Keeping an updated log of electrical team progress DavidB Electrical 4 31-12-2008 18:14
C programming problem... wasabi824 Programming 5 08-02-2004 01:04
Omg!!!!! #$#@$ 346 QP Dima Regional Competitions 2 08-03-2003 10:18
