Go to Post Meanwhile, it's water over the dam, spilled milk, etc. Let's drop the subject and get on with life. I am seeing people warming up their lawyerism, which is not a good thing when we are coming up on build season. - EricH [more]
Unread 23-01-2010, 15:41
pj174208 pj174208 is offline
Team 810
FRC #0810 (Mechanical Bulls)
pj174208 is an unknown quantity at this point
Exclamation Driver station say no code!
ok, deal is we build and deploy the code in labview, and it deploys succesfully, but then when we go to the driver... it has communication, but says no code! help?
Unread 23-01-2010, 20:26
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Driver station say no code!
So, you deploy the code to the cRio, and the driver station says it has no code.
Have you any code on the driver station?
Did I misunderstand something here? (I often do)
Unread 23-01-2010, 21:44
A common sequence seems to be logging into developer account, running code, then logging out of the developer account to run the DS.The problem is that when you log out of the developer tools, the code on the cRIO is aborted as well - at least this is true for LabVIEW.
The solution is to stay logged into the developer account and launch the DS from the Start menu.
Greg McKaskle
Robot code isn't loading onto driver station TigerDrive2391 Programming 2 24-01-2010 15:32
Deploying code from the 2010 driver station - Netbeans joshholat Control System 5 23-01-2010 15:01
Driver station not detecting robot code captainking NI LabVIEW 9 21-01-2010 10:39
2010 Driver Station Netbook Driver Account and Java joshholat FRC Control System 2 10-01-2010 15:04
Save code to Driver Station Comatose Programming 5 17-01-2009 18:48
