Go to Post Is the bottom slot just to make the whole thing look like a smiley face, or is it functional? - Chris is me [more]
Unread 23-01-2010, 13:19
rhoads2234's Avatar
rhoads2234 rhoads2234 is offline
AKA: Erin
FRC #2234
rhoads2234 will become famous soon enough
Problems Imaging the cRIO
Hi everybody,
We are unable to image the cRIO. When we try to, it says "The specified IP address is unreachable. Ensure that the IP address is on the correct subnet."
We've tried to reformat, but that ran for over half an hour. We can ping the port on the cRio, and the Computer we are downloading from has the IP address of 10.22.34.6 with a subnet mask of 255.0.0.0
We are trying to reimage with v19, and are coding in Java(And checking that box on the Reimage tool.)
Thank you in advance!
Team 2234
EDIT: We were able to download and reimage with another computer, but we don't get voltage readings on the Driver Station. When we try to run the code, the jaguars continue blinking, as if they have not been initialized.
Any ideas?
ALWAYS a mechanical problem!
Unread 23-01-2010, 15:49
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Problems Imaging the cRIO
Similar problem.
We are using LabVIEW and tried two computers, both got the same error.
We tried puting the cRio in Safe Mode, running the imaging tool and formatting it, turning safe mode off and imaging it, and that worked... better. It failed while uploading the configuration file.
We have not yet found a solution
Kettering Motorsports
Unread 23-01-2010, 17:45
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Hmmmmmm.....an epidemic? Same issue here....had to leave school before the reformatting was done. Will try again tomorrow.
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 23-01-2010, 17:49
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
Try reimaging the Crio with the classmate (should have an ip of 10.XX.YY.5) but make sure you have the latest update installed.
Thanks,
timytamy
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 23-01-2010, 17:53
apalrd's Avatar
More Torque!
VRC #3333
We tried first on the Classmate after installing the updates and rebooting. Then we tried another laptop.
Unread 23-01-2010, 20:52
Generally, my advice is to simplify the network as much as possible. Eliminate switches, other network connections, turn off firewall (completely off), turn off wireless network and any other types of IP. Just for grins, stop apps that don't need to be running.
Greg McKaskle
Unread 23-01-2010, 20:59
apalrd's Avatar
More Torque!
VRC #3333
No other networking. Direct connection.
After we turned on safe mode and formatted the cRio, it progressed further in the imaging process and then when uploading the configuration files it got an error... forgot the number but it involved timeout on reboot
Unread 23-01-2010, 21:05
gvarndell's Avatar
gvarndell gvarndell is offline
Software Engineer
AKA: Addi's and Georgie's Dad
FRC #1629 (GaCo)
Team Role: Parent
gvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond reputegvarndell has a reputation beyond repute
Not that there's a real answer in the other thread, just a happy ending, but I think this thread is the same problem as this other thread, isn't it?
http://www.chiefdelphi.com/forums/sh...threadid=80441
Robots never, ever, ever, ever break -- The Robot Repairman (Backyardigans)
Unread 30-01-2010, 23:48
BLProgram2010's Avatar
BLProgram2010 BLProgram2010 is offline
FRC #2534 (Robo Lake)
BLProgram2010 is an unknown quantity at this point
Problems re-reimaging again and again
We're use Labview. Every time we develop new code and try to deploy it or connect to the cRIO, there a error that says the vi's in the start up application will not open and will remain closed if you continue to apply and deploy. I found out the by using the 'cRIO Imaging Tool' and hitting 'Format controler', the pproblem is removed and we can deploy the code and run a drive test. But when we switch users back into the developer the same problem occurs and the cRIO needs to be re-imaged again. Running the 'cRIO imaging tool' with the format controler takes about seven minutes to finish; and ontop of that we still need to deploy and build the code which take another five to seven minutes. We seem to be spending a lot of time re-reimaging the cRIO to fix our problem. How do we fix it?
Unread 31-01-2010, 00:49
Re: Problems re-reimaging again and again
Originally Posted by BLProgram2010 View Post
We're use Labview. Every time we develop new code and try to deploy it or connect to the cRIO, there a error that says the vi's in the start up application will not open and will remain closed if you continue to apply and deploy....
Can you copy and paste the exact error message you're getting? What you're describing sounds very similar to an informational message that isn't an error, but before I give any advice I'd like to see what you see.
Unread 31-01-2010, 01:23
PriyankP's Avatar
PriyankP PriyankP is offline
FRC #0188 (Woburn Robotics)
PriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud of
Post Re: Problems Imaging the cRIO
Any ideas?
To receive the battery voltage readings, you need to power up the Analog Breakout attached to one of the cRio modules. + and - from the Analog Breakout go to the Power distribution board and use a 20 amps breaker.
THere is no additional code required to get the battery power readings.
~ Priyank
Champs Schedule Highlighter App [CD Thread]
#### XYZ Regional Finalists
Unread 31-01-2010, 09:34
Next time that happens just click okay and let it continue to see what happens.
Unread 31-01-2010, 14:07
When we try to connect/deploy to the cRIO in developer labview we get this message:
'This VI is part of a Real-Time Startup Application. All VIs on the target will be closed if you choose to apply and continue with deployment.'
The message also highlight the VIs- Auto. Independent; Robot Main; Send Image to PC; Async VI Agent; Acquire Image; HandleRuntimeErrors.
How Do we fix it and stop re-reimaging with the imaging tool with formatting controller everytime?
Unread 31-01-2010, 14:22
That's just a message you can safely ignore.
We all do.
It's just warning you that you're replacing the code that's already on the cRIO, but isn't that what you want to do?
Unread 31-01-2010, 14:33
It was an 'ID 10 T-Error'
Thank you so much
cRIO Imaging Error Scip Programming 1 20-01-2010 21:48
cRIO imaging alex42 FRC Control System 3 16-01-2010 20:05
cRIO imaging tool dnrobotics11 Programming 4 14-01-2010 23:32
Problem with cRIO Imaging Tool Doc Wu FRC Control System 7 15-12-2009 19:47
FRC cRIO Imaging Tool furiousgeorge Programming 1 06-02-2009 09:52
