Go to Post Basically, it just doesn't matter. - Mark Pettit [more]
Unread 23-01-2010, 20:59
fiferdc fiferdc is offline
AKA: David Fifer
FRC #1747 (Harrison Boiler Robotics)
fiferdc is an unknown quantity at this point
Possible 5v Power Distribution Trip
I was testing out a program to use the servos on the axis camera to have it follow a target. When the servos first moved, they yanked the axis mount and it fell over onto one of the nuts connecting power to the power distribution board. I've tested everything out and the only thing I can't get to turn on is the camera. I've noticed that there is a slight burnt smell around the 5V connection on the power distribution board and that when I hook the camera up to it, the 5V light doesn't turn on. Is there a way to know that I have tripped that breaker and not ruined the camera?
Unread 23-01-2010, 21:03
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Possible 5v Power Distribution Trip
Find a 5v wall brick and hook it up to the camera power supply.
We actually killed the 5v supply on the DSC of our practice robot last year... We stopped using the camera on the comp. robot before this happened, so we just left it. This year, we are repurposing the practice robot control system for this years practice robot, and we decided to use a wall brick and drag an extension cord because we were just doing vision tracking and not actually moving (just rotating).
Kettering Motorsports
Unread 23-01-2010, 21:08
AKA: David Fifer
Found a 5V wall brick and tested it; no lights. So how could the camera have been messed up?
EDIT: I just opened the camera up. Nothing seemed burnt to me.
Unread 23-01-2010, 21:18
apalrd's Avatar
More Torque!
VRC #3333
How was the camera mounted; was the nut in the back connected directly to the metal bracket or was it connected to a polycarb piece connected to the bracket (as an electrical insulator)?
If you didnt have an insulator, you would have fed the camera with more than twice its wanted voltage by connecting it to raw battery voltage. That would surely kill it.
If you did have the polycarb, it would probably still work and probably did not see ~13v, but still could have. Did you have the camera connected to Ethernet?
The lights on the side of the camera lens are orange when it has power but not in use, they turn green when the camera is connected to by the cRio (I think thats what it is, it could be the camera booting up and the camera boot is always tied to the cRio boot)
Unread 23-01-2010, 21:22
AKA: David Fifer
I guess I was only looking at the front of the camera. If you were referring to the back LEDs, then they light up. Then when do the front lights (the ones around the lens) light up?
So then if I haven't killed the camera, is there a way to replace the 5V trip in the power distribution board?
Unread 23-01-2010, 21:25
apalrd's Avatar
More Torque!
VRC #3333
The lights on the front light up when the camera is on. If it is connected to the cRio and the cRio is on, it will be green in under a minute. Try rebooting the cRio after plugging in the camera. To my knowledge, there is no way to fix the 5v supply on the PD board; we plan on using a new PD board on our robot.
Unread 23-01-2010, 21:31
AKA: David Fifer
Thanks. I hooked the patch cable up to the cRIO and they lit up. I was working on our spare robot, which had an additional power distribution board on it. Since we have two robots and one camera, I don't think there should be any problem with it on the other robot.
Again, thanks!
Unread 23-01-2010, 22:03
Shorting the battery through the camera has a good chance of breaking things. If it doesn't fix itself, there isn't much you can do to fix it internally (and I think it would be 'illegal' anyway).
Did this happen on a 2009 or 2010 PD? On a 2009, you almost definitely blew the ground return trace on the 5V power supply. On a 2010, there is a self-resetting circuit breaker in line that should heal in a few seconds. However, I wouldn't be surprised if a 2010 still broke, depending on how the short happened - it is a LOT of energy to handle!
You could try powering the camera off of the 5V in either the DSC or the 2009 Analog Breakout, as they are all the exact same circuit. Not sure if its legal for competition though.
Unread 23-01-2010, 22:14
It's not legal, per <R45C>, however we have done it off the digital sidecar before.
Power distribution board does not give power to access point bitsoglass NI LabVIEW 3 17-02-2009 12:07
Power Distribution Block Bambi Electrical 3 12-02-2008 10:25
Power Distribution Block kE7JLM Electrical 4 17-01-2008 08:48
New Power Distribution jsmith234 Electrical 6 03-02-2007 15:05
Power Distribution xxmaddjxx Electrical 13 30-01-2005 00:43
