Go to Post It's one thing to post thoughts, guesses, opinions - that's all good ... However, it's [different] to make statements claiming first hand knowledge & facts without actually having first hand knowledge, facts, or accurate information. - Jason Morrella [more]
Unread 23-01-2010, 15:10
TigerDrive2391 TigerDrive2391 is offline
None #2391
TigerDrive2391 is an unknown quantity at this point
Robot code isn't loading onto driver station
Hello. We are having trouble getting our robot to work. We have successfully built and deployed a basic project (changing from arcade to 4-motor tank drive), yet our driver station can't read any code on the robot. It was working fine until we attempted to install an update. We believe that we improperly installed it before, but now we have fixed it. Please help.
Unread 23-01-2010, 21:40
Re: Robot code isn't loading onto driver station
You think you're deploying code successfully, but the Driver Station disagrees? One thing that can cause that symptom is not having the proper image in the cRIO. Have you re-imaged it with the v19 file?
Unread 24-01-2010, 15:32
None #2391
Thanks for your help we figured it out by ourselves and it was the C-rio not being reimaged properly.
Deploying code from the 2010 driver station - Netbeans joshholat Control System 5 23-01-2010 15:01
Driver station not detecting robot code captainking NI LabVIEW 9 21-01-2010 10:39
Save code to Driver Station Comatose Programming 5 17-01-2009 18:48
Loading Code Onto 2005 RC chris31 Programming 13 08-11-2006 07:45
