Go to Post ....FIRST helped me realize how much i enjoy engineering, so that i NEED to do well in my classes if i want to reach my goals. - the_short1 [more]
Unread 23-01-2010, 23:03
Jim.D Jim.D is offline
FTC #1983
Jim.D is an unknown quantity at this point
LabView and PS0C
Does anyone know how to access the PSoC from a LabView application ?
The are several blocks to set and read data and the other functions but no block to initialize communication or open the card for access. Using the other VI's alone give a device not connected error.
Also if anyone knows about the possibility of getting the labview souce files for the driver station application. They would be helpful in figuring out how to communicate with the card.
Thanks for any input.
Jim
Team 1983
Unread 24-01-2010, 03:12
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: LabView and PS0C
The start communication VI is what is needed to "open" the connection to the board. Make sure the LED on the I/O tab is lit... it indicates that the board is communicating with the driver station and I/O data is being sent to the robot. Also, if you are using the enhanced API, then you need to select the enhanced API on the driver station I/O tab in the configuration dialog.
Unread 24-01-2010, 07:55
To clarify, most teams will want the robot code to interface with the cypress board via the DS. That was, I believe, what Joe was describing. Is that what you are doing, or are you wanting to communicate to it from a PC or dashboard? If so, you want different code.
Greg McKaskle
Unread 24-01-2010, 12:47
FTC #1983
I can comunicate with it thruogh the driver station but wanted to learn how to access it straight from a labview app like you can with the sensor DAQ. It looks like many of the blocks are provided I just don't know how to start the communication. Maybe as a VISA USB device ? If anyone has any example that would be great.
Thanks
Jim
Team 1983
Unread 14-02-2010, 17:30
fkm300 fkm300 is offline
fkm300 is an unknown quantity at this point
Has anyone figured this out yet? We are also looking at how to get it working.
Unread 14-02-2010, 17:45
What is the use case? Please describe in detail.
paper: Set and display your Auto-Mode using LabVIEW and the Driver Station PhilBot Extra Discussion 0 11-02-2009 12:32
Labview 8.5 and encoders MorbidAngel NI LabVIEW 1 15-11-2008 13:57
Drag and drop (labview) kamocat NI LabVIEW 7 28-10-2008 08:05
Labview and Sensors Joohoo NI LabVIEW 4 09-05-2008 20:44
Camera and Labview phrontist LabView and Data Acquisition 1 28-01-2006 21:07
