Go to Post Success is the indescribable feeling you get when you see something you worked so hard on in front of thousands of people. - SlamminSammy [more]
Unread 24-01-2010, 02:09
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
Re: pic: Team 1708 Idea #1 rev. A
Originally Posted by GUI View Post
Have you considered how having all six wheels flat on the ground will affect turning ability? 6wd is very maneuverable when the center wheel is slightly lower than the others (allowing one end to be slightly off the floor when turning), but with a suspenstion I don't see how you could get that affect. You may have already considered this, just trying to help you make sure there aren't any surprises when it gets built d:
I'm also curious about this; seems that when you include a suspension system on a 6wd, you're losing a major benefit of that wheel configuration. Are you planning on using any omniwheels on the corners?
Unread 26-01-2010, 13:17
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Eddie might have some more to say, but I think the idea's to mount the suspension using theaded rod, and then a nut on top could be tightened to limit the maximum expansion of the spring, so the outside wheels could be raised to normally sit ~1/8" above the center wheel when under weight.
--Ryan
FRC 766, 2015-, Mentor
pic: (RP) Team 1708 Idea #1 1708xMr.Roboto Extra Discussion 24 27-01-2010 12:01
pic: team 1708 D_Price Extra Discussion 2 06-03-2008 19:37
pic: Team 1708 Teaser robotboy11 Extra Discussion 2 15-02-2008 10:31
pic: Team 1708 Robot! robotboy11 Extra Discussion 3 13-02-2008 21:30
