Go to Post We will all win in the end. - JaneYoung [more]
Unread 24-01-2010, 08:57
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Realistically facing the challanges of elevating your robot
If you're thinking of a pneumatic piston, you might want to do some calculations regarding how much force you can get from one, and how much air it takes to get that much force over the distance you need to lift the robot.
It might be more feasible to get the job done with a motor driving a winch.
We don't have a design yet, but we have a lot of ideas. Here's one that a student came up with and made a model
http://www.youtube.com/watch?v=V254FdHQnyE
Unread 24-01-2010, 10:12
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
Steel cable with a winch that can lock is our method. We have tested and proven the speed and power we need. We are using an arm to get it their but the steel cable will do the support. We indent to hook from the side of the tower and drop out pipe loops for other robots to hang from. thease loops will be on the opposit corners of the robot away from the tower. This will allow the robot in the first zone to hage with out leaving it. They will be able to score right up to the end and then hang at the last few seconds.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 24-01-2010, 11:21
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Originally Posted by joeweber View Post
... We indent to hook from the side of the tower and drop out pipe loops for other robots to hang from. thease loops will be on the opposit corners of the robot away from the tower. This will allow the robot in the first zone to hage with out leaving it. They will be able to score irght up to the end and then hand at the last few seconds.
Could your robot hang from those pipe loops you mention if they were on another robot? I mention this because grabbing the 7 ft high bar and grabbing much lower ones (4ft? 3.5ft?) might be even trickier to do with the same mechanism. We think being able to hang from a range of bar heights will increase the scoring opportunities. We're encouraging other builders to incorporate a bar or bar simulator on their side away from the tower.
Unread 24-01-2010, 13:05
joeweber's Avatar
Coach team 1322
We will have a second hook low that can hook just above the 20 inch level. That hook will only have to hold our robot. When we are hanging from another robot no robot will be able to hang from us.
Unread 24-01-2010, 13:37
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
This video shows 190 hanging from the top bar (which, if I remember, was a bit higher than this year's)
http://www.youtube.com/watch?v=Q5nnG...eature=related
Unread 24-01-2010, 14:52
joeweber's Avatar
Coach team 1322
c. TOWER Contact ROBOT Volume - During a MATCH, ROBOTS in contact with their ALLIANCE TOWER may extend beyond their NORMAL CONFIGURATION volume but may not exceed the FINALE CONFIGURATION maximum volume.
d. FINALE ROBOT Volume - During the FINALE, ROBOTS may extend up to the limits of the FINALE CONFIGURATION maximum volume.
Does everybody understand the above two rules? Before the 20 second finale are we allowed to open the robot size as long as we touch the tower, but we are not allowed to hang? After the 20 seconds do we still need to touch the tower to open up?
Unread 24-01-2010, 15:03
GaryVoshol's Avatar
Cogito ergo arbitro
True
I find nothing that says this. You could hang in auto mode, as long as you were touching the tower when you expanded beyond NORMAL CONFIGURATION.
During the FINALE 20 seconds, you may expand whether touching the tower or not.
(since 2004)
Unread 24-01-2010, 11:41
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
We have done the calculations and will be verifying our findings with a prototype ASAP but you can likely get the force you need over the the full distance you need with pneumatics.
How would you have built your team's robot differently if the robot could expand? Chris is me General Forum 23 23-04-2009 06:50
MARS 1523 is Facing a Problem.... Salbert Team Organization 24 30-04-2008 20:52
pic: Vex Elevating turret 2 1902_Battery_SGT Extra Discussion 5 10-11-2007 22:55
The burning question: How many ringers can your team REALISTICALLY score? waialua359 Rules/Strategy 82 16-03-2007 01:21
Starting Facing Backwards? Fusion364 General Forum 8 21-01-2005 11:31
