Go to Post "We used to shut the robot up in a box and send it away from home. Now we just suffocate it." - GaryVoshol [more]
Unread 24-01-2010, 10:37
Phil007's Avatar
Phil007 Phil007 is offline
Hangin' with my Gnomies
AKA: D. Phillips
FRC #2013 (the Cyber Gnomes)
Phil007 is an unknown quantity at this point
Team 2013's Inventor prototype
Here is a pic of our design so far. This year, our 'engineering' help isn't available and my background is architecture... thus the sleek design. Hopefully it works. I would appreciate any comments.
Some design specs are as follows:
- Wheels will be custom made from aluminum, but we are looking into UHMW as a lighter medium. The wheels as pictured will weigh around 6 lbs each in aluminum, and around 2 lbs in UHMW. We don't know if UHMW will work, so if anyone has any experience with the stuff, please comment.
- Wheels are powered by four CIMS with Banebot planetary's... ya, I know, they are not the trans of choice, but they are compact for this design, and they have not let us down yet. Keeping our fingers crossed !
- The kicker is spring loaded, will be drawn back into loaded position with an FP motor/trans, released with leadscrew device. We wanted to stay clear of pneumatics as weight could be an issue. A rotary sensor is mounted to adjust the kicker for long & short ranges. The kicker (as tested in our halls) is able to move the ball 50ft through the air before landing. Quite powerful.
- Ball magnet between front wheels (still testing, using 1-1/2" PVC coated with tool grip paint... I'll update that later)
- So far, the team does not want to attempt climbing for the 2 points. They feel that we will be able to score the two points to justify the decision. However, if they decide later to add something, the curved orange panels open up, similar to a ladybugs shell, to expose the inside mechanisms
- The current design allows over the hump & through the tunnel travel, whichever will be of more benefit to the alliance.
Looking forward to some comments,
Cheers.
Unread 24-01-2010, 10:42
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Re: Team 2013's Inventor prototype
Very nice slick design. I like it, nice and simple yet effective.
Have you thought about buying those type of wheels from a place like AndyMark? (www.andymark.biz)
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 24-01-2010, 11:02
Phil007's Avatar
AKA: D. Phillips
Yes, we have looked at AndyMark (several times) but it comes down to cost. We have great sponsor who has a 4 axis mill with indexing head to mill the aluminum/UHMW, and he will do the work as a sponsorship donation. Otherwise, the AndyMark wheels are out-of-pocket.
Thanks for the comment.
Unread 24-01-2010, 11:22
Edoc'sil's Avatar
Edoc'sil Edoc'sil is offline
FRC #2531
Edoc'sil has a spectacular aura aboutEdoc'sil has a spectacular aura about
The mechanums are massive, 24 lbs for wheels? Maybe you can lighten them up a bit, swiss cheese style. Beyond that the design looks simple but effective, similar to the direction that my team is headed. As for your concerns with weight, I would be genuinely surprised if your bot weighed of 100 lbs but I do not know how your boy is constructed so i am not the best judge of its weight. My only concern is the lead screw, my team has used it before and had it fail. Just be careful with it, and test it a bunch. Better for it to fail in the shop then at a regional.
Here lies a toppled god-
His fall was not a small one.
We did but build his pedestal,
A narrow and a tall one.
Unread 24-01-2010, 11:23
Alex_Miller's Avatar
Alex_Miller Alex_Miller is offline
2175 College Mentor
AKA: Alex Miller
Alex_Miller is an unknown quantity at this point
Send a message via AIM to Alex_Miller Send a message via MSN to Alex_Miller
Be careful when going over the bumps with those wheels, if you go up at any sort of angle the vectors wont really work out and you'll go in odd directions.
Unread 24-01-2010, 11:39
Phil007's Avatar
AKA: D. Phillips
I like the swiss cheese thing. This is the first year that we have played with Inventor and I really like the iProperties screen. We have placed some holes in areas and have reduced the weight by a quarter, but again, I'm no engineer so I am not sure if its structurally sound.
Mom was right... I should have gone to university for engineering instead of architecture !
Unread 24-01-2010, 11:51
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Not sure what the slot on top of the robot is for, but I would be careful; a ball that gets stuck in it may be considered carried. Sloping the top of your robot in some way along the long axis may alleviate this problem.
Unread 24-01-2010, 11:57
Edoc'sil's Avatar
FRC #2531
After you do the swiss cheese thing you can use stress analysis in inventor to see if it is still strong enough. Idk how exactly the stress analysis works, I will likely go ask my mentor for some basic tutorials.
Unread 24-01-2010, 12:02
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
I think that this year this is the most common type of design we'll see. A robot that has rollers to hold the ball and then right behind the kicker mechanism is some sort of third class lever kicking mechanism, either powered by pneumatics or surgical tubing. Also 4wd mecanum seems to be a common topic on here this year so I'm suspecting we will definently see a lot of it coming up. Are you guys planning to use just normal tank drive or have you been looking at omni directional drives at all.
Unread 24-01-2010, 12:06
nitbaj's Avatar
nitbaj nitbaj is offline
AKA: Nitesh Bajaj
nitbaj will become famous soon enough
I think you actually should be fine. With the testing we've been doing with mecanums, the robot seems to straighten itself out before it actually starts going over if you hit it at the wrong angle. Obviously, you probably can't go up sideways, but I'm pretty sure you won't have too many problems otherwise.
Team 241's Turret Prototype ontop of the Harvester Prototype Dantvman27 Robot Showcase 39 08-02-2009 22:53
pic: team 2013's current pit area, ORANGE!!! scirobotics Extra Discussion 10 08-03-2008 16:53
Team 1711 prototype 7-11number1 Robot Showcase 21 27-01-2008 21:50
Team 100's prototype spinmunky Robot Showcase 10 15-01-2007 12:56
