Go to Post If this doesn't show up in spotlight at some point I'm almost going to be sad. - Andrew Schreiber [more]
Unread 24-01-2010, 11:16
mike263's Avatar
mike263 mike263 is offline
FRC #0263 (AFTERSHOCK)
mike263 is on a distinguished road
Send a message via AIM to mike263
question about what we can use
can we use a fishing reel on our robot to pull back somthing for a shooter ?
Unread 24-01-2010, 11:21
Josh Drake's Avatar
Josh Drake Josh Drake is offline
Engineering Mentor
FRC #5403 (Aluminosity)
Josh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond repute
Re: question about what we can use
We prototyped it, and failed. The reel we got had a clutch that couldn't tighten down hard enough. It slipped. If you don't want to kick too far, and your willing to get a good reel you may have better luck, but remember the force you will need to release the casting mechanism. The reel is designed to disengage with little force pulling on the line.
07'-10' FRC 343
11'-12' FRC 2751
13'-14' FRC 3494
15'-16' FRC 5403
Unread 24-01-2010, 11:23
I don't see anything in the rules that would prohibit it.
Unread 24-01-2010, 11:25
Edoc'sil's Avatar
Edoc'sil Edoc'sil is offline
FRC #2531
Edoc'sil has a spectacular aura aboutEdoc'sil has a spectacular aura about
It's legal alright, but nowhere near strong enough. There are better ways, say pneumatics.
Here lies a toppled god-
His fall was not a small one.
We did but build his pedestal,
A narrow and a tall one.
Unread 24-01-2010, 11:32
mike263's Avatar
thanks i have a few large reels i would like to try
Unread 26-01-2010, 18:54
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
i would suggest a CIM (or any other motor) winch, fishing reels are made so that they use a friction device, similar to car brakes, so that it's a lot harder to snap the line, so it WILL slip, as it is made too
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
can we use our crate? (was: Another question) Chris3632 General Forum 5 11-02-2009 21:39
Can we use other joysticks? (was: Question) Sincrum Kit & Additional Hardware 6 09-01-2009 12:15
Is there a restriction to what sensors we can use? Robot Dude 0101 Kit & Additional Hardware 28 11-01-2005 22:43
What type of joysticks can we use? Wacko324 Control System 11 29-02-2004 10:04
What formulas can you use? Tton General Forum 7 04-11-2003 00:33
