Go to Post Man, I never thought I'd have to cite a rule during the offseason. - Karibou [more]
  #61   Spotlight this post!
Unread 23-01-2010, 01:12
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
Re: Robot Lifting
This is such an elegant solution you should be applauded for thinking outside the box! The one problem I see is the 84in right cylindrical rule. if you make a 28" robot, and you'll have to assume your alliance partner is driving on it's 38" dimension that will determine the size of the platform on the vertical frame assembly. that accounts for 66". Since the rules state that the entire robot in it's finale configuration must fit within an 84" cylinder, I'm not sure you can manage a ramp long enough to allow for a 45 degree ramp angle to accommodate your alliance partner. You may have to do some fancy timed folding. I haven't looked at the numbers close enough so I don't know if that will indeed be an issue.
Steve
Originally Posted by Sunshine View Post
Here is an idea that our team came up with that we believe would work and is outside the norm of lifting a robot that others may not think of. I was extremely proud of all of the ideas that the students generated this year for lifting. Besides this idea, they also came up with a great idea for lifting using the vertical bars. For the record, we are not using either idea. We are using the KISS method (Keep It Simple Students) and believe that we will have a lifting robot that can do the job quickly, efficiently and is simple.
I include this diagram within the spirit of Gracious Professionalism
  #62   Spotlight this post!
Unread 23-01-2010, 17:27
MikePres's Avatar
MikePres MikePres is offline
A Dreamer
AKA: Michael Presman
FRC #3088 (Kill-O-Bites)
MikePres has much to be proud ofMikePres has much to be proud ofMikePres has much to be proud ofMikePres has much to be proud ofMikePres has much to be proud ofMikePres has much to be proud ofMikePres has much to be proud ofMikePres has much to be proud ofMikePres has much to be proud of
Send a message via ICQ to MikePres Send a message via MSN to MikePres
Re: Robot Lifting
Me and couple of my teammates had this idea that we call "wings". basically we thought of folded arms that unfold outside the robot and create 2 forklift-like platforms on both sides of the robot.
Our mentors said it's impossible and we're gonna break our wings on our first try.
what do you think?
2010 Captain of...
Kill-O-Bites (#3088) - Crazy Enough to Work!
2009 Israel Regional Rookie Inspiration Award! =D
2010 Israel Regional Semi-Finalists and Coopertition Award! ^^
the first team ever to lose due to a coin-toss in the semis ^^"
Visit us: | our site (explorer only) | Blogger | twitter | YouTube | Facebook| FIRSTwiki | kob3088@gmail.com |
  #63   Spotlight this post!
Unread 23-01-2010, 17:32
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Robot Lifting
what do you think?
Nothing is impossible given enough time, weight, and money.
You'll have 150 lbs of robot 2+ feet out from your torsional point. So your ramps will need to support 300+ lb-feet of torsion. Not impossible, but not something to be undertaken lightly.
We were looking at holding to the vertical bar and flipping our robot upside down. At a lever arm of around 4 feet when the bot was horizontal, and considering the grab points on the bar would have been around 6 inches apart, you're lookin at over 1/2 ton of torsion / shear on the tower (and your gripper). Not something we felt comfortable engineering to.
  #64   Spotlight this post!
Unread 23-01-2010, 18:03
fuzzy1718 fuzzy1718 is offline
MTU class of '15
fuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant futurefuzzy1718 has a brilliant future
Re: Robot Lifting
what do you think?
Someone did something similar to this in 2007. Granted it wasn't as high, but they made it work. I belive they way they did it was each "wing" was rotated up once the alliance partners were on them. Then a leg would pop down to hold the wing in place after power down. It was kinda cool to watch
What FIRST has taught me:
Money is not everything.
In order to change a culture one must change the hearts of the next generation.
The fish rots from the head down.
Why we do something is often more important than what we do.
Repeated success is often sown on the backs of a few, but reaped by many.
  #65   Spotlight this post!
Unread 23-01-2010, 18:39
Chris is me's Avatar
AKA: Pinecone
Re: Robot Lifting
That's a lot like an idea I had at the beginning of the year. I'm not doing it because it takes a LOT of engineering to get it right, with almost no room / weight / motors for a kicker.
  #66   Spotlight this post!
Unread 23-01-2010, 19:00
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Robot Lifting
Can you fit that inside the 84" FINALE CONFIGRATION cylinder? Your robot alone is about 34" (including bumpers). Your forks could only extend 22 or 24 inches on either side. Would another team take a gamble on balancing on a fork that wasn't at least as wide as their robot?
(since 2004)
  #67   Spotlight this post!
Unread 24-01-2010, 07:12
George Nishimura's Avatar
George Nishimura George Nishimura is offline
Lurker
George Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud ofGeorge Nishimura has much to be proud of
Re: Robot Lifting
THis is why we decided against the ramp/wings idea too.
  #68   Spotlight this post!
Unread 24-01-2010, 11:16
Josh Drake's Avatar
Josh Drake Josh Drake is offline
Engineering Mentor
FRC #5403 (Aluminosity)
Josh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond repute
Re: Robot Lifting
Ditto.
The idea came up, but the sacrifices to do it were too great.
If you could do it and still play the game for the other 1:40, it would be bennificial to the team.
07'-10' FRC 343
11'-12' FRC 2751
13'-14' FRC 3494
15'-16' FRC 5403
  #69   Spotlight this post!
Unread 24-01-2010, 11:54
spiffyspleen's Avatar
spiffyspleen spiffyspleen is offline
FRC #2635
spiffyspleen will become famous soon enoughspiffyspleen will become famous soon enough
Re: Robot Lifting
Has anyone found a good hook to order for getting onto the bar? Or, is everyone doing a hook just going to make their own?
  #70   Spotlight this post!
Unread 24-01-2010, 11:59
Tom Line's Avatar
Re: Robot Lifting
Spiffy, just buy a 1/4" aluminum plate from mcmaster and use a bandsaw to cut your hook out of it.
  #71   Spotlight this post!
Unread 24-01-2010, 15:29
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Re: Robot Lifting
At first, I was excited about this idea, but after some time I realized myself the problem -
3 words: Plane of Platform.
This system cannot be static, but if it lifts the ramps above the paltform's plane, no prob.
TEAM 2230 ZECHARIA'S ANGELS
2009 Microsoft Israel FRC Regional Winners!
2009 Microsoft Israel FRC Regional Chairman's Award Winners!!!
2008 Microsoft Israel FRC Regional semi-finalist.
2008 Microsoft Israel FRC Regional Delphi's "Driving Tommorow's Technology" Award winner.
2008 Robot Driver
2007 GM/Technion Israel FRC Regional semi-Finalist.
2007 GM/Technion Israel FRC Regional Xerox Creativity Award winner.
2007 Robot Driver.
  #72   Spotlight this post!
Unread 24-01-2010, 15:40
Aren_Hill's Avatar
Build Nifty Things
Re: Robot Lifting
what do you think?
you can get "wings" to work, we called them forks
http://www.chiefdelphi.com/media/photos/27790
A guy who likes robots.
  #73   Spotlight this post!
Unread 24-01-2010, 15:52
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Robot Lifting
I'm not climbing on that.
  #74   Spotlight this post!
Unread 24-01-2010, 16:24
Aren_Hill's Avatar
Build Nifty Things
Re: Robot Lifting
They got redone for IRI that year, less risky
  #75   Spotlight this post!
Unread 24-01-2010, 17:01
MikePres's Avatar
A Dreamer
Re: Robot Lifting
where did those platforms come from?
2010 Captain of...
1070's 2007 Robot Lifting AznPrincess3089 Robot Showcase 8 19-03-2007 19:37
Team 192, Robot Lifting Teaser Joobacca Robot Showcase 7 02-02-2007 17:46
Lifting one vs. lifting two jgannon Rules/Strategy 1 14-01-2007 17:37
robot lifting doomsdaytank Rules/Strategy 2 14-01-2003 16:41
Lifting goals patrickrd Rules/Strategy 6 17-01-2002 17:58
