Go to Post Embrace the challenge, dont shoot it down. - waialua359 [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 22-01-2010, 10:53
KC1AJT's Avatar
KC1AJT KC1AJT is offline
Head Mentor
AKA: Patrick
FRC #6617 (Bellinghan High School Black Hawks Robotics Club)
KC1AJT is an unknown quantity at this point
Question Need Visual Basic Help
I am in the process of designing a scouting program.
I have the following code:
Private Sub teamnum_KeyPress(ByVal sender As Object, ByVal e As System.Windows.Forms.KeyPressEventArgs) Handles teamnum.KeyPress
Dim allowedChars As String = "0123456789"
If allowedChars.IndexOf(e.KeyChar) = -1 Then
' Invalid Character
e.Handled = True
End If
End Sub
But I would like to add the function of a backspace key.
Mentor - Team 6617
_____________________________________________
Student Years - Team 61
2011 Boston Regional
2011 BAE Systems/Granite State Regional
2010 Northeast Utilities FIRST Connecticut Regional Finalist
2010 Boston Regional
2009 Archimedes Division
2009 Connecticut Regional
2009 Boston Regional Regional Winner
Unread 22-01-2010, 11:04
riptide's Avatar
riptide riptide is offline
The Software Dude... LabView and VB
AKA: Jeff
FRC #1165 (Paradise)
riptide will become famous soon enough
Re: Need Visual Basic Help
You have to use the ascii character for backspace which is 8.
Try this:
Dim allowedChars As String = "0123456789" + Chr(8)
Unread 22-01-2010, 11:06
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
The solution to this problem in DOS-mode Pascal was to read ASCII character 8. In C, you would use \b or \x08. See this table for a VB constant called "vbBack" that may work equivalently.
Unread 22-01-2010, 11:11
KC1AJT's Avatar
Head Mentor
AKA: Patrick
Try this:
Thanks! Works Perfectly!
Mentor - Team 6617
Unread 22-01-2010, 11:13
riptide's Avatar
AKA: Jeff
the constant vbBack will work as well.
Unread 22-01-2010, 17:15
KC1AJT's Avatar
Head Mentor
AKA: Patrick
Smile Re: Need Visual Basic Help
Thanks for all the answers, I will release the the database and cooresponding programs as soon as they are finished.
Mentor - Team 6617
Unread 23-01-2010, 14:45
KC1AJT's Avatar
Head Mentor
AKA: Patrick
Ran into another issue I have a checkedlistbox with 6 checkboxes and would like to put code in a clear button to uncheck all of the 6 checkboxes.
Mentor - Team 6617
Unread 24-01-2010, 08:25
FRC Key Volunteer Trainer
AKA: CrazyNate
Two ways you can do it...
1. If they are the only checkboxes on the form(or panel, etc):
For each ctl as Control in Me.Controls
    If TypeOf ctl is Checkbox then CType(ctl, Checkbox).Checked = False
Next ctl
2. If there are other controls you don't want to mess with, you'll need to just specify each checkbox by name, such as:
CheckBox1.Checked=False
CheckBox2.Checked=False
Nate Smith
nsmith@smythsoft.com
Unread 24-01-2010, 12:22
riptide's Avatar
AKA: Jeff
You want to try something like this. Place it in the ButtonUnchecked clicked sub.
For i As Integer = 0 To checklistbox1.Items.Count - 1
checklistbox1.SetItemChecked(i, False)
Next i
Unread 24-01-2010, 12:25
KC1AJT's Avatar
Head Mentor
AKA: Patrick
Ok I finally found it. After a day on Google, here's the code:
Dim i As Integer
For i = 0 To Me.CheckedListBox1.CheckedIndices.Count - 1
Me.CheckedListBox1.SetItemChecked(Me.CheckedListBo x1.CheckedIndices(0), False)
Next i
Mentor - Team 6617
Visual Basic basicxman IT / Communications 11 13-11-2007 23:43
Visual basic Help plz Jevin H IT / Communications 4 30-03-2007 18:57
Visual Basic help needed. Cody Carey Programming 1 25-02-2007 15:06
Visual Basic dddriveman Programming 12 20-03-2004 13:03
Help programming in Visual Basic xxlshortys Programming 0 06-04-2003 08:54
