Go to Post You're on a team, weren't you taught Gracious Professionalism? It doesn't only apply to competitions, it applies to the real world. - Zac Schofield [more]
Unread 24-01-2010, 14:07
jman1783 jman1783 is offline
FRC #2900 (Mighty Penguins)
jman1783 is an unknown quantity at this point
Can't connect your imaging tool to the cRIO?
I spent a few hours today struggling with our Classmate and trying to get it to connect to the cRIO. Everything was wired up correctly, direct connection via an ethernet cable from the Classmate right to the board, and the Classmate made the right switch to use the cable as a crossover. But it just wouldn't detect the cRIO under any circumstances!
After calling Chuck Harris from Oakton HS, he gave me a great pointer - disable the wireless on your laptop/classmate/whatever, before booting the imaging tool. Sometimes the tool wants to use the wireless connection instead of the wired, and nothing you can do will convince it otherwise. We disabled that, then disabled and re-enabled the wired connection under 'network connections' in the control panel, and everything worked like a charm.
Maybe this is common knowledge, but if not, there you go.
Go Penguins and Team 2900!
-Justin Manzo
School Without Walls
cRIO imaging tool dnrobotics11 Programming 4 14-01-2010 23:32
Imaging Tool does not find cRIO aeasson FRC Control System 2 10-01-2010 20:39
Problem with cRIO Imaging Tool Doc Wu FRC Control System 7 15-12-2009 19:47
cRIO Imaging Tool HELP PLEASE!!! furiousgeorge FRC Control System 2 08-02-2009 22:44
FRC cRIO Imaging Tool furiousgeorge Programming 1 06-02-2009 09:52
